Not sure where you got 267mm, the TUF is 330mm.?? That AMD card is 267mm long. Offcourse it will fit since the 3080 TUF is longer and I have that in my case. Read the opening post. There's enough data on which cards fit.
No, rx 6800/6900 xt asus tuf is 320mm long. Its 20mm longer 3080 tuf and 8mm longer official spec of t1?? That AMD card is 267mm long. Offcourse it will fit since the 3080 TUF is longer and I have that in my case. Read the opening post. There's enough data on which cards fit.
No it's not. It's 299mm. I would know, I have it. The Asus 3080TUF that is,Not sure where you got 267mm, the TUF is 330mm.
OP was asking about the Asus TUF 6900 XT, you responded saying it was 267mm long and I responded saying it was 330mm long. Guess I should have specified 6900 XT not the 3080. (Newegg lists this as 13" and Asus also lists it at 13" and 320mm, 13" is actually 330.2mm so I have no idea which is right.No it's not. It's 299mm. I would know, I have it. The Asus 3080TUF that is,
And I was talking about the AMD card, just not the Asus variant because I forgot they make these also.
I could not fit my old 1080TI MSI x trio with 325mm So if it's 330....
It's not though because I read that it's 320 so will fit.
Prob still to heigh though.
At 320mm in length, it should fit in the 1.2 version of the case. It will not fit in the current version of the case (v1.1)Anybody know will it fit rx 6900xt asus tuf? Its just 2cm longer rtx 3080 tuf and looks like it must fit
Hi,Where did you get this picture? Would love to talk to somebody that actually has the block.
Same here with my 5900X. It goes crazy whenever you open a page or an application... with balanced (Recommanded) power plan.Compared to the Nouvolo I've heard it does much better but can't find that comparison anymore.
I think I've read it in this topic too.
I'd like to hear what your temps are when it's finished and with what bios settings/ PBO enabled or not etc.
Am currently underwhelmed with the temps both the Nouvolo and the 5900x produce.
The Nouvolo compared to the Velocity has an 8c celsius gap. Which I think is a lot.
I finally have my temps under control and now my idle temps are at 35 degrees roughly with a 27% pump speed (EK 3.2 DDC PWM)
Somehow at 30% the pump has a very audible and annoying whine that disappears when going to 50% for example.
Actually have reverted the power plan in windows back to balanced, which sees the temps spike back up towards 45 degrees roughly.
I noticed stuttering in the Witcher 3 with the energy saving setting enabled in windows power schemes.
I also have PBO active.
With the energy saving scheme the 5900x stays at 35c, but with balanced scheme it spikes to 60c with very light stuff like opening a folder in windows.
It's driving me crazy.
Thanks for the heads up, I was about to buy one, now I'm gonna wait!Unrelated note.....after getting my T1, my use of a LinkUp PCIE4 riser cable has been shortlived. Was getting screen blanking and system restarted with my RTX2070 on auto mode. Don't know if I got a lemon or simply mounting it in the case damaged it.
I have a 5950x and it used to do this with older bios versions on the asus x570i motherboard. I forget the version where it stopped doing this, but I have mine updated to the most recent version and don't have this problem. Is your bios the latest agesa release? Mine never spikes when doing simple tasks anymore and it's voltage stays relatively flat when idle/simple tasks. Used to jump all over the place like you stated with your 5900x.Same here with my 5900X. It goes crazy whenever you open a page or an application... with balanced (Recommanded) power plan.
Okay great, hope you can get it straight without breaking the fins! Such a big block of metal gives me confidence it can suck up the heat the 5900x dumps.Yeah, I'll report back, I finally got my 5900x yesterday. My block came with some bent fins near the edges and slight damage to one of the O-rings, and they didn't include any extras. I'm going to try and straighten out the bent fins, but it shouldn't degrade the performance that much. Visually the cold plate is very flat, little to no distortion, it's like looking in a mirror. It's a big chungus block though, I put it on the scale for a laugh, 920g without a pump on it!
I have the latest, but it's a beta version. Can't check right now but I thought it was 3604 which I can't find on the website so that might be it. Thinking about reverting back to the second to last one just to be able to exclude it from the list.I have a 5950x and it used to do this with older bios versions on the asus x570i motherboard. I forget the version where it stopped doing this, but I have mine updated to the most recent version and don't have this problem. Is your bios the latest agesa release? Mine never spikes when doing simple tasks anymore and it's voltage stays relatively flat when idle/simple tasks. Used to jump all over the place like you stated with your 5900x.
Good to know I'm not the only one with these problems and it's actually not just my settings or pc. If I had known this I would have never upgraded from my 8700K.Same here with my 5900X. It goes crazy whenever you open a page or an application... with balanced (Recommanded) power plan.
Fantastic find!!! I have searched everywhere for this review because I had read it in the past but didn't bother saving it for future reference....Hi,
Found the picture in the review of the page but don't think you will be able to contact the person.
But found that, and he compared the metal block with the aquanaut (5°C difference)![]()
Having PBO enabled isn’t going to help bring your temps down unless you just have it enabled to be able to undervolt via the curve optimizer (no OC).Compared to the Nouvolo I've heard it does much better but can't find that comparison anymore.
The chipset fan on X570-i is a 30mm one.Yes I have done that using the settings Optimum Tech suggests with an offset of negative 30. Does nothing for temps though, just results in better clock speeds at the same temp supposedly.
Without PBO temps are a little better sure, but not that much. I think around 5c idle, and nothing under load.
Meanwhile I get micro stuttering in games, and temps of over 83c and nothing seems to work.
My system:
Asus X570-i
AMD 5900x
Nouvolo Aquanaut
EK DDC 3.2 PWM with heatsink
G.Skill 32gb ram 3600mhz
Corsair SF750
J-Hack
Asus 3080 TUF
Linkup 20cm pcie 4.0 riser
2x Adata sx8200 pro M.2 SSD 2TB
2x Noctua 15mm chromax fan
(Waiting on the black 25mm q3)
Coolworld 240mm full copper rad.
2x GW.05 2.4/5.8-7.125GHz Monopole Antenna Taoglas
Silverstone remote control SST-ES02-USB
I have ordered a chinese waterblock which should get temps down a few degrees, and will be adding a 25mm fan in the future.
I have ordered a Noctua A4x20 for chipset and SSD cooling, and a Thermaltake heatpad to replace the stock one on the chipset but they have not been delivered yet.
Beyond that I tested with different settings and the only thing that really helps temps is windows power saving scheme.
It downclocks everything but does keep it at 35c idle without spikes. Not using it though.
Meanwhile micro stuttering keeps happening with new windows install, new install of ac valhalla, performance energy scheme, and pbo.
I'm lost in what else I could possibly do.
Right now my 8700k performed better in games.
