    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
gwertheim
938
1,555
I mean they actually listened to random input, AND do not already have a solution for the card themselves?
I imagine they basically have a whole design team, and probably early access to the final product to base new waterblocks on so this surprises me in a big way.
Hey it's a good idea, why not explore it, if it works, it works, if it doesn't they lose a couple of hrs of work and some material
Reactions: DrHudacris
PKAWA
490
488
No definitely, and since I'm planning on buying the card I'm all for it. I think it's great, I'm just surprised by their reaction is all.
Hope they'll build something like this.
gwertheim
938
1,555
The engineering team have a narrow scope of vision and focused on making the best block possible with the best thermals possible. Anything else doesn't matter.
carrefinho
34
122
This response doesn't signify that they don't have a "normal" water block design ready IMO. EK doesn't make these integrated pump solutions unlike Alphacool so I guess it's safe to assume they only designed what they always do, which is a conventional full cover block. This idea is kinda out of their scope so it's great that they appreciate these novel approaches.
WalkingSun
Can somebody tell me what the 2nd and 4th color options are for the FormD because it just doesn't show it for me, thanks only 1, 3 and 5 are showing.
ciaran clare
72
64
Well....I took out my crystal ball just for you and it comes out with this prediction...lol
Thank you very much @tinyitx, see theirs no need to be sarcastic @gwertheim with your remarks about time travel, you should just get yourself a crystal ball like tinyitx. XD
So I emailed EK with the above image...they think it's a great idea and are forwarding it to R&D :D
You sir, are a genius. this would be so freaking cool to see
ciaran clare
72
64
@tinyitx, i have one problem with your airflow diagram for the rtx 3090, the fan near the bracket is fine as i believe its supposed to work like a standard blower style fan, however the other fan is intended to go straight through the card and (in a normal case) go straight up to the cpu cooler. Your diagram suggests the hot air is going to come out the side of the gpu and out the top, . However in sandwich style cases like the t1 the fan is going to blowing straight into a sheet of metal. I dont have my T1 yet so i dont know how much clearance there is between the metal/motherboard and the backplate on the gpu, however im assuming theirs not a lot of clearance their so that fan is going to struggle, depnding on clearance i dont think the top fans will be able to pull that hot air out very well.
DrHudacris
918
1,720
I think with this GPU, the PSU fan should face the GPU to aid exhaust.
TSOF
113
181
Clearance depends on your config - it's been suggested you orient the PSU so that it directly intakes the air from the GPU and expels it up.
gwertheim
938
1,555
But time travel will be great. It's like back to the future 2 where you can get a sports betting book and make money
tinyitx
2,279
2,338
My diagram is intended to show what you are saying.
Yes, fresh ambient air will pass through the other fan and exits in a direction perpendicular to the card (ie not via the top edge of the card). Then, those air has to go up, either being sucked upward by the 2 top case fans (in this case, the effectiveness could be questionable...this might or might not work...someone has to try it to confirm. I agree that one important factor is the clearance between that fan and whatever is blocking it) or being sucked into the PSU (which is in a flipped orientation) 's fan and then expelled upward.
