Prototyping Expandable custom loop ITX Case with distroplate built in
diceboii13
132
229
Hello guys,
I'm planning to make an ITX pc case, that can support watercooling (AIO, Custom loop), expandable for cooling preferences with a built in distro plate in the front. The distro can support almost any D5 pumps out of the box, and im planning to design a ddc version too. It can be built by off the self hardware. I'm on the end of the CAD planning, and I have nice renders about it. I also sent it to manufacturers, but prototyping is an expensive thing. Thats why I put my idea there, to get some help about experienced members! Unfortunatelly, I want to make the first prototype, then go in to indiegogo or kickstarter to make it happen. Only just with renders, and no testing i cant write my opinion about my work, and I cant send anybody, to test it. If you guys have any idea how should I start it, please help me! Thanks!
1,186
1,113
That is very cool, I really like the idea of the distroplate in this form factor. I am currently working on a custom loop for my Ghost S1 and one of the most challenging parts is location for pump/reservoir. I look forward finished product. What are you thoughts on radiator support?
Reactions: diceboii13
diceboii13
132
229
Thank you, as you can see in the second picture when you expand it, u can fit a 240rad both top and bottom, so you can make a full loop with separate rads for gpu, and cpu. The bottom one pull air under the case and a top rad can exhaust. But you can use only one rad, if you want aswell. :)
Reactions: fabio and rfarmer
McSpain
44
52
Looks very promising. I had a similar concept in mind for a future project. I'm looking forward to see more from yours.
diceboii13
132
229
Thanks! As I can manufatcure a prototype, things gonna be easier.
ermac318
200
143
Any consideration to accommodating 280mm radiators in top and bottom? 280s are much more space efficient with regards to heat dissipation. A 360mm radiator is only single-digit percentages better than a 280 but requires 3 fans so it's louder and the fans are smaller so need to run a higher RPM for equivalent performance.
As an aside, if you can make a distro plate, have you considered just making a distro plate for an existing case, such as the Ghost or the upcoming Sliger?
Alur
79
46
Subbed, a really interesting project you have created.
However, make the distro plate an optional feature, for example if you use an AIO it will be unnecessary and that space might be used for 2.5 drives or more compatibility. Also, might wanna study to change the holes on top and bottom, since they look somewhat restrictive and hard to manufacture and might affect structure integrity.
It looks pretty damn good, my thumbs up on overall design.
diceboii13
132
229
For the truth, i didnt think about the 280 rads. But I tested it, and works out well. The only thing to modify in the case is the top/bottom radiator/fan holder. I need to add more holes to it because the 280 is wider than the 240. But fits nice. There is some pictures about it.
I just found a thicker 3D modell so dont freak out lol.
And the distro plates for existing cases is a good idea. Maybe I will try it out. Thanks for the idea!
diceboii13
132
229
I thinked about it when I started, but thats a hard question. The 2 selling point for this case could be the distro plate, and the expandability, so I dont really want to make these as an optional feature. I want to give them out of the box. Maybe I will give the normal frontpanel in the box aswell if the price is exceptable. If too high I will do it as a choice at the buying.
The holes is hard to manufacture, i know, i talked about it with some manufacturers, so it will be a bit different at the end. But I like this one so much... :( Thank you btw!
Tazpr
318
219
Very cool and unique design with the distro plate as you're tackling something that is a pain point for so many water-cooled sff systems. With the addition of 280mm support that really brings it up a notch. I also really like the ventilation design on the top, gives me 80's sci fi vibes.
Have you spoken to some of the manufacturers that make some of the cases for other Forum case brands, like Lian-Li or Jonsbo - who I think also use Lian-Li but I've seen people go through them to get prototypes made - also Velkase maybe able to assist if Michael's not too busy with the Velka 3/5/7 projects.
I think prototyping is always going to be expensive, it'll cost you a large amount for your first few cases, but if you intend on trying to get the case backed on Kickstarter or Indiegogo you'll need to get some publicity for the case through content creators since custom water-cooled sff systems are a niche already.
The idea has heaps of potential and I can't wait to see how it goes, but take it slow and don't rush to crowdfunding til you've create enough awareness.
Also +1 to just creating the distro plates for existing cases, lots of potential buyers on here for custom distro plates and if you were to do one for the Sliger SM570/580 or Ghost you'd probably get a lot of interest.
diceboii13
132
229
Thanks! I'm happy if its got your attention :D I wrote an e-mail to the lian-li factory, but didnt replied yet. And i wrote a message to Michael, I hope he can help, maybe with some tips would be awesome. I just got a ghost's 3D modell so if I have a bit of freetime, will try to do a distro design for it.
Nanook
732
718
Nice concept! A distro plate would be ideal for small cases.
I'm not a big fan of expandable cases at the moment. As most don't look expanded as when they are small. The expanded state just looks temporary to me. Your renderings looks great though :)
diceboii13
132
229
Thanks! The expandability is just an extra if you dont want to watercool it, you can just close it like a normal sff case.
diceboii13
132
229
As you guys said, I tried to make a distro for the ghost, but end result isn't stunning. The PSU is too close to the frontpanel, and there is almost no room for the DDC pump. Its makeable, but not too aesthetic. What do you think? Any Idea?
Nanook
732
718
What about placing the distro plate on the bottom? It may or may not be contained within a L tophat on the bottom. Intake will be from the side panels, and exhaust through a top radiator (inside a L tophat)
diceboii13
132
229
Thats sounds good, and i have a good idea about it. I try it out. Thanks!
Reactions: Nanook
