Completed DSE Breathe - A 7.3L Vertical Format ITX Tower
Thehack
Creator
Mar 6, 2016
2,814
3,670
J-hackcompany.com
Reactions: caniplaymayo
KSliger
Sliger Designs
May 8, 2015
855
3,186
I see. Thanks for telling me. I value it greatly.
Looks like this is per the LiHeat riser. Checked 3 GPUs - all have the same insertion issue.
Here's the 3 biggest takeaways during the build process:
  1. You need a low-profile power cable (hopefully Sliger can include one in future batches). Since your power cable will come out the bottom of the case, it'll stick out and your case won't be level.
I will add this as an option on page for next batch.
Ambushes
49
32
So what can the user do about the GPU? My case just arrived but reading about the GPU issues worries me.
KSliger
Sliger Designs
May 8, 2015
855
3,186
You should not have problems, just push the slide clip back all the way and the card slides in. I would loosen the power switch nut first as well.
You can remove the screws holding the riser in, insert the GPU, attach the riser, then reinsert the mounting screws if you don't want to mess around with trying to angle it in.
Reactions: Biowarejak and DSE
veganzombiez
27
29
Yep. It was my preference to have the case made out of steel so that it would be even more rigid with my latest design changes. We'll go back to steel for the next revision to really minimize flex.
How much strength will going full steel add to the spine's structural integrity? I'm tossing around a couple thoughts for that variation, mostly just for funsies:
  1. Drill a small opening next to the PSU (HD cage position), and add a mini front panel.
  2. Replace PSU with HD Plex, and use the existing PSU hole for dual 40mm fan mount and/or mini front panel.
  3. HD Plex + 3.5" HD or second 2.5" array for NAS.
gunpalcyril
294
319
"I like heatsinks" -> Love that quote!
MSI GAMING x TRIO:
325 x 140 x 48
DSE:
  • Maximum card height: 152mm (bottom of card PCIe tab to top of power connector wires)
  • Maximum card length: 330mm
It will fit =) Will post some pictures when it is done.
I have a 8700k (not planning on OC), I will use the nh-l9i with a redux 25mm fan.
Thanks for the reply!
Just a heads up, if you are using the noctua b9 redux 1600, don't use it. The stock fan spins much faster and performs better, the b9 redux is more for airflow, despite its small size. I've tried it, and got worse temps.
KSliger
Sliger Designs
May 8, 2015
855
3,186
We have two white and one red still available for anyone that's looking to get one.
PM me if you'd like me to hold one until weekend when you get paid or anything like that.
Reactions: DSE
LaboonTheWhale
31
37
@KSliger I have the black on the way, tempted to order that red to compare the 2. I could I just sell to someone online. (as returns can be hassles on both parties) I couldn't decide the color in time :p
anoldfriend
44
61
Thanks for the insight!
What would be the best cpu heatsink option for this case? (silence over temperatures)?
Waiting for the DSE =)
Reactions: DSE and Damascus
veganzombiez
27
29
@DSE, @KSliger:
Good news is that my GPU no longer has problems fitting in.
Bad news is that the retention clip snapped in half. This was probably 99% my fault since I was pretty rough with it on my first installation attempt. In this case, while the GPU was properly installed, I pulled up on the GPU, and the mating dongle went right through.
The GPU still fits snugly without the retention clip, so it shouldn't be an issue.
Reactions: anoldfriend
LaboonTheWhale
31
37
Probably an axp-100 modded to take a slim noctua fan under the heatsink
I hav emy axp-100rh and trying to think of how to fit that underneath and fasten it. I realized that if I "pull" air up through the radiator, then the fans are going to collide with radiator and probably wont spin. If I flip it down with fan pushing air up through the rad, then its not going to have much breathing space. How did you go about fastening yours? zipties?
Damascus
553
395
Mine is en route as we speak, fetting my info from here. I'll probably use zipties or see if I can get a bracket printed out
And this is a decent resource for the various fan configs. Different cooler but similar enough design that the results should carry through
https://www.youtube.com/channel/UC4AS6UstwzMCm3tFf191iPw
DSE
DSE
Feb 8, 2017
137
390
I've personally only tried two coolers; the Cryorig C7 and C7 Cu, and I can tell you the C7 Cu is definitely worth it if you compare my old and new thermal tests. The C7 Cu runs noticeably quieter since overall temps are cooler.
DSE
DSE
Feb 8, 2017
137
390
@DSE, @KSliger:
Interesting.
LaboonTheWhale
31
37
I wish they would show how they mounted the fan. Because I just modified my axp-100RH and I cannot ziptie the fan without it colliding with the heatsink fins or the fan blades hitting the mounting plate.
Damascus
553
395
Yeah, it's quite frustrating. I'll let you know how mine goes
Reactions: DSE
