Hello SFF guys,
Firstly I want to tell you that I don't know nearly anything about CAD softwares and just drew this on an online CAD website which wasn't useful.
For now, I have only an idea to make a case about 3.14 liters (if not possible, at least around 3.5 lt) including low profile dual slot gpu and flex atx psu if possible. It will be ultra portable and will still capable of doing some work and gaming.
Layout is basic, I tried to drew its rear side and named it "Flexpy", because it consists of flex atx psu and you know 3.14 the pi number. I didn't want to name it as flexpi since it might refer to raspberry pi.
I thought it can handle up to 65w tdp cpus with a max 40mm cpu cooler support. ( NH-L9i is considered here)
Possible setup can be like this;
Ryzen 5 1600 or i5-8400 cpu
Gtx 1050ti low profile
M.2 SSD
Seasonic 300w flex atx psu
And here is the basic layout I drew;
As I said, I'm super noob about these things, I need your help if it is doable and got the idea for now. Also, I created a poll, please vote it.
edit: measurements are in cm.
Update 1: Managed to draw and got the render of left panel and pattern.
M.2 SSD
