Could we pay extra for 2 of each?They are the same, it doesnt matter what side you will put in.
Yeah, you must order it like from a regularly webshop, this form is needed, because we need to know what we should manufacture. When we are gonna make it, Ill let you guys to finalize your configs.Just a quick question.
Would be have time to review the order before payment?
Just in case we put something incorrectly on the form.
Hell yeah! just mention it before manufacturing. Ill let you know the date.Could we pay extra for 2 of each?
Right now 11 availableJust curious-how many of the 30 cases left based on number of forms submitted?
I just added to your formOkay I submitted with the choice of mixed. Should I email you to change it to one set of each?
You will get a different distro backplate, that you need to screw to the frontplate. If you need it with the first batch, I can add to your line.I have just submitted mine. how do I get both distros in the event that I might watn to swtich pumps in the future?
I think yeah, but need to ask @alauderAbout the idea of the first 30 cases being special. Would it be possible to engrave the number of the preorder (1 to 30) into the case or the distroplate? It would make these cases more personal.
Me too man ?been looking forward to this day haha ?
I think (LxWxH): 359 x 152 x 30 or 45mm is the max, so basically every rad fits, but to be sure, check the dimensions of the rads before buying. Xflow is working, but its more tricky especially for hard tube builds, because you may need some extra 45 or 90 fittings. For soft tubes its the same as any other rads.What's the maximum dimensions of the radiators available? Would an X-flow radiator work for example? The one I am specifically looking at is (LxWxH): 334 x 144 x 30mm
