Is possible custom color for some parts (expandable top and bottom) for additional cost?
Or separate additional parts for self painting.
I think it will be possible, but depends on the final manufacturers color palette. Now I talking with a hungarian company, but they require drawings from the case, so I making them asap. Then I can ask from prices, and color palette if the price will be good.Is possible custom color for some parts (expandable top and bottom) for additional cost?
Its possible, but not in the top, maybe in the back of the case, between the gpu and the mobo cutout. For first I want to get the case with the most neccessary features, then we can add things like the handle. I think about a leather or some textil/fabric holder, for better cable management and aesthetics. If I leave 2 holes for an additional handle in the back, it can work I hope. I gonna think about this idea!Would it be feasible to add a handle for portability of the case? Or since the case extends adding a handle would add unnecessary stress on the screws holding the extension for the case in place.
Its a power button, but didnt change the color of it hehe. Not yet, if i can find a decent modell, I gonna update it.What is a black/red stop plug at distroplate?
And no render with flowmeter?
Under Specifications both CPU Heatsink measurements are stated for 2-slot backplates – presumably one of these should be 3-slot?dicecases.com (dont take the shop prices seriously, its just for testing purposes)
ah thanks, didnt saw it.Under Specifications both CPU Heatsink measurements are stated for 2-slot backplates – presumably one of these should be 3-slot?
I'm sorry didn't see your replay, thank you man!It's a beautiful case. Before that I check only slim-Desktop, but this... Love you, man. I've never gotten a water-cooled computer, but I see your case and wanted to buy it
I'm my calculations around December. The final design is done like 99% just waiting for the manufacturer to get some price offers. Then we make a second prototype, for testing, and its almost done.Have you got some updates or date, when ppl can buy this case?
Guy, you do this so fast. From prototype in your mind to real case. I literally jump for joy when I look at this case and read your messageI'm my calculations around December. The final design is done like 99% just waiting for the manufacturer to get some price offers. Then we make a second prototype, for testing, and its almost done.
Thanks man! Currently I'm working on it so its not 100% final jet. The reason for that is simple. There is 3 expands both sides.Very nice! Looking forward to it.
I was just looking at the configurator and noticed that while you define three different expands under "Specifications", one can only choose between two different expands when configuring the case. Additionally it only says "large" or "extra large" expand, without mentioning any measurements. I wouldn`t know which to order to get the right parts. Perhaps you could clarify that?
