What is the PSU position, exhaust or cables on top?
Loving the case Dan.
After all these changes, will the configuration of 2x80mm fans remain available?Yes 80mm, 92 or 100mm are supported.
For the feets see my newest update. For HDD i do not get the question. For screws it will be M3 on everything and 6-32 UNC on PSU. I also do not get the last question.
Any ideas or recommendations on cable management would be great.
Nice! Just one suggestion if I may: would it be possible for the 240 rad slot holes to be moved such that they share the top ones with the 280 slots, this way a 240 rad would sit as high up on the bracket as possible. As it is currently I think the top of a 240 rad would be close to being level with the pump block so might cause air to settle in the pump block.
@dondan Have you changed the feet from the first post? Because in the first page picture the feet look to be horizontally aligned with the case and in the latest CAD model they seem to "get wider" to sides and front/back when going up from the bottom. Anyway, straight feet would look much better, as they seem to be in first post. I think there are more people than just me concerned with the new looks![]()
- Was talking about the HDD if it is possible to rootate 180 so that the connectors are facing on the opposite side to hide the cables better. But then again I was asking your suggestions where can we possibly place our psu/usb/sata cables. From your renderings it might be at the case floor but its tight. Of course I could place them in between the radiator and PSU or top of PSU (thus no need in rotating the hdd @180 , but for me it would just be laziness.
Do you mean on a radiator , then I need radiator specs.@dondan does the c4 support push pull config
For cable management just wait for my tests and pictures. On the C14S config bottom isn't a exhaust zone it is intake. I think 2x 140mm on the side is more than enough exhaust.Any ideas or recommendations on cable management would be great.
I'm considering going with Mini-ITX, mid-high GPU, Noctua NH-C14S and full modular SFX PSU.
If there is not enough exhaust, I will add more fans on the bottom.
No@dondan At this point near the end of revisions do you have any idea/estimate based on previous case releases when you might be able to take orders? I think I saw you were having Lian Li manufacture them but I could be wrong, have you worked with them before and do you know what the lead time would be?
Hi Dan, did you see this suggestion I made? Do you think it's worth changing?
