Cool! And I think that this case will become very popular considering the thermal output of the new alder lake cpu’s
At this point, I would only pick the S620 if I needed the air cooler size. Any plans for a window panel?
Is maximum pump height 80 mm when using 45mm rad and 25 mm fan?
And is 140 mm the maximum radiator width? If so, the Alphacool ST30 280mm V.2 rad can not be used.
Reminder: Arctic 280 uses P14 fans which are 27 mm. And the radiator itself is 38 mm. Also see the data sheet.I will work on this after the release.
Max pump height of 80mm is on 35mm rad with 25mm fans like the Arctic 280 AIO.
It depends. Directly mounted to the bracket 141mm is max. If you put first fans and than radiator on the bracket the maximum would be 162mm![]()
my guess is, based on a few videos I saw (mostly in regards of optimizing the original A4, but also the Cougar QBX): To reduce the amount of turbulences and "focus" the airflow towards the radiator / fans.@dondan would you explain again how the airflow bracket works and why it helps?
does it benefit both AIB design and 30x0 FE?
I could made the feet out of 4 parts. Than it would be possible to unscrew the middle part with the spikes
Is there some technical reason that the max radiator width is 141? Is it possible to make it 143 without sacrificing other features? The Alphacool st30 280 V2, which is 143 mm, is not the best performing radiator but the multiport feature makes it easy to fill/drain the loop when not using a reservoir.I will work on this after the release.
The design looks good though, I don't really mind the feet, they are certainly unique and look pretty industrial and there is always the option to design and print custom ones. To me it's not worth the extra complexity of making them in 4 pieces but other people might disagree. They might also look better without the chamfer on the front and back edge as the case is quite cube-oriented with the sharp top edges so having them not chamfered and about 15mm rather than 20mm would in my opinion look better.
I'm a little confused why so many people are interested in retaining the flip-able paradigm. It seems like we're pretty confident at this point that the best thermal performance comes when the layout is inverted. Why would you want a mode that is categorically worse? Just for the sake of the added "feature?"
@dondan is it possible to add a small fan to the rear of the case?
cu, w0lf.
See my thermnal design pictures@dondan would you explain again how the airflow bracket works and why it helps?
There is not more space or it will interfer with the clips. If you want to install bigger ones - as I said just switch fan and rad position.Is there some technical reason that the max radiator width is 141? Is it possible to make it 143 without sacrificing other features? The Alphacool st30 280 V2, which is 143 mm, is not the best performing radiator but the multiport feature makes it easy to fill/drain the loop when not using a reservoir.
For the feets see my newest update. For HDD i do not get the question. For screws it will be M3 on everything and 6-32 UNC on PSU. I also do not get the last question.- So if I have a pen drive I have to stuck it at the back?Just kidding. USB-A for legacy devices.
- So you are leg man!Need that many legs for stability bro? You can cut some to improve airflow a bit.
- HDDs can be mounted the other way around right (cable management)?
- Be sure to limit number of screw sizes...
Proposals where to tuck in the cables, aside the top of psu?
I will test it after I got the sample.Hi Dan. Do you also test the optimum deshroud setup like in the ncase m1? How are the Temps when you place the top fans as exhaust?
