IMO, once a case exceeds ~12L it may as well be sized to fit mATX.
Yeah, 12L is totally feasible. Even allows for AIO support if done right.IMO, once a case exceeds ~12L it may as well be sized to fit mATX.
Yes please.In my current drawing I am back to top io and classic vent holes. But I plan to test mesh panels. I also have the idea to make front IO as a kit seperate (that includes a front panel and the io part).
That's indeed a tricky situation. Perhaps monster GPUs were only a fad ?As always before a new GPU release I am unsure if the C4v2 should be 13.37L (ITX + 3Slot GPU up to 330mm) or 15.4L (ITX/mATX + 4.5 Slot GPU up to 340mm). It looks like NVIDIA pushes smaller sizes GPUs with "Nvidia SFF specs" and RTX 5090 FE rumors to be 2 Slot GPU.
The case will outlast the internals. So if you change the mobo three or four times during the lifetime of the case, the savings will add up and become substantial (i.e. you could buy a second case, just with the money you saved by using mATX mobos).Most comments on Reddit said that want mATX because boards are $60 cheaper. But does someone how want to save $60 on a board buy a $220 case?
Finally, what I'm currently thinking is : if the C4 v2 is going to be restricted to ITX, and nVidia is going to seriously push for 2 slot GPUs again... why would anyone consider the C4 v2 instead of the A4-SFX ?
Sure, the C4 v2 will fit a taller CPU cooler, and slightly bigger GPUs. But it will be almost twice as big as the A4-SFX... that's a huge counter-argument.
Regardless of your choices (which are certainly difficult to make), I'll continue to follow the development of this case with interest.
You might also want to take a look at the just announced M2 Evo (15,5L / mATX mobo / ATX PSU / 4 slot GPU / 144,6mm cooler) as a point of comparison with the options you're currently weighing.
Ummm Dan can we see some pics for the 13l prototype……..?To be honest I do not care about other product releases. Talking about the R1 for me its looks like this case is just optimized for flat packed. You will get many open surfaces, that are have lower production costs, untypical decisions how to do sheet metal design (could result in low stiffness), outer screws in 2024 and a design where some parts needs to be mounted while assembly the case around it that you can't easy remove. Also, if you attach a big panel with 4 screws you can have rattle spots at the middle part. This is just my humble opinion.
Old information. All outer panels will be anodized.
Most community work moved to SSFGurus and now SFFHub on Discord. This is where the core of the cummunity moved to. But I will try to add more content here too.
In Europe the product was available for 1 month including ~ 2000 units. I never thought it would be sold out that quick and it was also regulated what my resellers ordered. Yes, US launch was not that good because I thought bringing the second batch to Newegg. This was before I made the decision to stop making v1 and working on v2. This was also not a smart decision because I thought dev on v2 would be quickerBut many US customers could buy if from ComputerOrbit & OcUK and this was communicated for first batch.
Update:
As always before a new GPU release I am unsure if the C4v2 should be 13.37L (ITX + 3Slot GPU up to 330mm) or 15.4L (ITX/mATX + 4.5 Slot GPU up to 340mm). It looks like NVIDIA pushes smaller sizes GPUs with "Nvidia SFF specs" and RTX 5090 FE rumors to be 2 Slot GPU. Keep in mind RTX 40x0 series was developed under the estimation it will be 600W. At the end it was 420W and on the Super cards we saw much smaller heatsink because they were made under correct information. I do not think we will see cards in the next 5 years that will outbreak the current 420W limit. So 3 Slot with 330mm length is what is really needed.
mATX vs ITX
It could be the situation if i do the mATX version of the case most customers will use ITX like it was seen on the M1 Evo. In my last survey 58% voted for mATX and 42% for ITX, but is it reprehensive? Most comments on Reddit said that want mATX because boards are $60 cheaper. But does someone how want to save $60 on a board buy a $220 case? Another argument of having more choice in mATX is also not that big because many boards are cheaper made than the few ITX boars we have.
My heart is for the 13.37L version not because of the nice volume but more for its core features that is more representative for what kind of cases DAN Cases does (ITX and good GPU compatibility). The 15.4L version is noticeable higher and only really needed if upcoming GPU generation would be 4 Slot like we saw on RTX 4090 TI prototypes. On the other hand mATX in 15.4L is a banger and would be a great selling point, but is this the approach the community and DAN Cases have? I never used my C4v1 as a daily driver I used my 13.37L prototype.
Regards
Daniel
People who build cheaper mATX-builds just do not post. No time, no beautiful photos. ITX costs more, but what is much worse - arrives significantly later AND are much harder to get (availability is bad). Usually they pop up in sales 6 month after new chipset launch and stay in retail much shorter than mATX with much less models available.It could be the situation if i do the mATX version of the case most customers will use ITX like it was seen on the M1 Evo.
Because of the dual 280 radiator support that allows for higher end setups with still decent noise levels. No way to do that in an A4-SFX.why would anyone consider the C4 v2 instead of the A4-SFX
Note: this was done in the Korean market. They claim it can be extrapolated, but I am not sure it’s that simple. ATX is pretty popular in many parts of the world over Matx and per hardware unboxed a lot of Matx b650 are straight trash.From TechPowerUp:
“The most popular B650 motherboard form-factor is Micro-ATX, which holds a staggering 88% of the volumes. The 240 mm x 240 mm PCB size has everything buyers of the platform would want, since there aren't too many add-on cards to use these days besides a graphics card. The standard ATX (or larger) demographic is 11%. Mini-ITX remains a novelty, and it only has 1% of the market.”
B650 Chipset and Micro-ATX Form-factor Dominate Socket AM5
InterestingNote: this was done in the Korean market. They claim it can be extrapolated, but I am not sure it’s that simple. ATX is pretty popular in many parts of the world over Matx and per hardware unboxed a lot of Matx b650 are straight trash.
Interesting
Because at 26L, it's no longer an option.The A3-SFX is the mATX case option, I'm not sure why anyone would be talking mATX in this thread.
