Noise turbulences because of close distance to the side panel? Plz share us nice pictures![]()
Running Borderlands 3 benchmark. If you hear a lot of white noise, it's because your volume is cranked up and there's no microphone directly in front of the panel. Also neighbors were mowing the lawn.
What's the current status of this project?Update: Loud thinking
I got my new RTX 4070 today. I'm in heaven!
It barely reaches 70ºC under stress! And it's not even undervolted.
The 4070 uses a 8 pin PCI connector, the 4070 Ti uses the 12VHPWR connector. I have the 4070 Ti in my Ghost and just bought the Corsair 12VHPWR cable and made sure it clicked when I plugged it in. This is only a 250W card so I am not too concerned about it melting as long as it is plugged in properly.Nice one, congrats
Is it an 8 pin or 12VHPWR connector it uses? If the latter, how did you find that connector considering all of the "issues" it has had with user error of plugging it in correctly etc.
Depends on which 4070 model, the 4070 Founders Edition uses the 12VHPWR connector for example. But guessing the partners models uses the traditional 8 pin.The 4070 uses a 8 pin PCI connector, the 4070 Ti uses the 12VHPWR connector. I have the 4070 Ti in my Ghost and just bought the Corsair 12VHPWR cable and made sure it clicked when I plugged it in. This is only a 250W card so I am not too concerned about it melting as long as it is plugged in properly.
Welp, since the Strix B550I is having compatibility issues with 4000 series cards I had to find another board for now. Picked up a used Aorus X570SI and had to downgrade the Black Ridge with my L9I. Things are slightly noisier and a few celsius higher but at least no more crashes.
I've had this problem when I first put my build together. A MB bios update fixed my issue.Hello!
The front USB-C of my DAN A4 v4.1 is not operating normally. Whatever device I connect it just keeps connecting and disconnecting, even though I had barely used it.
Does anyone know if this is a part that is sold separately?
what is your CPU+GPU load? if the load is high and stretch the SF450 to its limit then probably yes, by going to 600/750W versions the fan may not need to ramp as much. Heck with SFX you can go to 850W right now with options from FSP and LianliGuys, my PSU (Corsair SF450 GOLD) gets too loud under heavy load. Can I fix it by changing to a 600W version?
