I would say don't be hopeful. I got into the 5th batch back when it's estimated delivery date was July 5th. And you know how that's going haha.Do we have an ETA for batch 5 being sent out? I'm planning a LAN for the 5th of August and was hoping to have it before that![]()
All at work. There is no time to make a photo. Tomorrow we send.any pics of batch 4?
Are you talking about the legs? Yes in all 3mmI liked the little feets that were used in the case! Is this the default for all sent cases?
I'm noticing that the side panels are shorter than the front panel. Could this be corrected in future revisions?
Potential fans: scythe slip stream 120mm 12mm height
Always been a firm believer in 120mm fans ( even if they are bigger then the cooler base ) as it pushes more air at lower sound.
Noticed that too, presumably due to not accounting for the 2 bends which reduce the height in reality, while it may have lined up in designI'm noticing that the side panels are shorter than the front panel. Could this be corrected in future revisions?
Yes, I'm working on it.I'm noticing that the side panels are shorter than the front panel. Could this be corrected in future revisions?
realistically you could just grind down the excess on the front panel yes? thats where the excess seems to beYes, I'm working on it.
