It'll be more than plenty and you'll have the extra power if you ever need itI believe i ordered their lowest wattage.. which is the 220W. But guryhwa sent me a 400w anyways lol.
@Ketchup
@Ketchup
It'll be more than plenty and you'll have the extra power if you ever need it![]()
Pretty jelly of the Le sometimes wish that's what I had gone with lolPSU arrived! Build quality seems excellent. Cannot wait to get everything installed.
I think thumb screws would be too Tiny for case feetI'm also curious what the thread size is for the screws that hold on the side/ front panel on my rev 2.
I feel like replacing them with thumbscrews might make neat case feet.
Meaning they would be too short to do anything or not sturdy enough or what?I think thumb screws would be too Tiny for case feet
Motherboard - M3@sergiiua
Could you tell me what the thread type for the mobo standoffs and pci fastening is so I can order myself some color anodized thumbscrews?
just too skinny i feel itd look silly, theyve got those adhesive feet or even a nice pair of ncase feets would look nice too youd have to hold em in with bolts instead of threading the case for em but theyd look nice if youd be willing to drill lolMeaning they would be too short to do anything or not sturdy enough or what?
I just want to elevate it a bit to prevent scratching on whatever surface I put it on/ scratching the underside of the case when I set it down.
Would probably need a small washer and that's about it. I'm probably gonna put some on mine eventually I think I'm not entirely sure yet. @sergiiua should be receiving batch 5 blanks today or should have rather. I'm kinda looking forward to seeing how my logo turned out lol sadly I decided to go ahead and have mine powder coated mainly due to some unforeseen costs out of my budget that's keeping me from having it cerakoted.
I'd say you're very correct. The 7700 would be fine. But k varient I wouldn't go with. And if you go with the 7700 I'd save some money and go with the h270i Strix Mobo. Which is what I went with fantastic board still have the dual m.2 as well.@soulazy, unless you're thinking of undercloacking that 7700K, i would said that your setup might generate to much heat for that case and especially for the L9I. It's meant for 65W TDP CPUs and the 7700K is a 91W TDP. Here's Noctua's recommendation. As they stipulate, you should only use the L9I on a very well ventilated case when paired with a 7700K. That's not the case (no pun intended) for the Mini itx 3.42L even with the big vent holes and it's not the point either of this case.
Maybe someone has a better take on this, but this is what I'm seeing.
