Stalled Custom_MOD MINI
Ziths
28
I also think you should just make the front panel a slightly bit more hollow to support one or even two 7mm thick 2.5 inch SSDs, would this be possible to do for revision 4?
Acalanata
38
25
Brazil
I have not seen anyone questioning this, but come on: is Intel's cooler box compatible with this case?
Or even the Ryzen 1400 cooler box (Wraith stealth)? Whats are the size of these coolers?
Reactions: Ziths
Ziths
28
The cooler from Intel is huge. Suitable low-profile solutions up to 38mm
The Intel stock cooler is considered low profile. It's a shame that this case kind of requires you to use a NH-L9i (if you want the best cooling). If you could just widen the case by a couple millimeters, it will support a ton more options, including the stock Intel cooler.
I also think it looks awkward, maybe you could move it to the front of the top panel on the CPU side?
Your thoughts on this @sergiiua ?
Ziths
28
If you want a bigger case, there are loads of options out there. If you want a small case, you have to compromise.
I don't want 'a bigger case'. I'm talking about a few millimeters in the front for dual 2.5 inch drive support and a couple millimeters on the CPU side to support a Cyrorig C7 for example. There are no cases like this one that support this.
sergiiua
Jan 11, 2017
1,156
2,057
Ukraine
www.custom-mod.com
+$15 I will make no more a problem.
Curiosity
Apr 30, 2016
754
885
34
Florida Panhandle
Did you run the extension cable between the motherboard tray and case floor?
If you didn't you might be able to get less of a loop up top.
I can't wait to build into mine!
Is yours a batch 1?
Harouken
37
SF Bay Area
Haha I didn't even think of that but I'll leave it as is for now :3
Yea it is from batch 1. I wish it had a removable front panel as that would have made everything infinitely easier XD
raksan
41
55
Cambodia
Finally built it :3
Another cat for scale
I misread "another cat for sale", lol. I wanted this case too by seeing just how small it is. But what bug me is it wouldn't fit an internal ac/dc. Btw, I went to Lone L4, bought all the required component... now just waiting for the case.
TinyAudio
188
132
Could you fit a AC-DC above a 1050ti low profile GPU?
I have the case sat on my desk but have major money issues :( car went poof!
QuantumBraced
507
358
CustomMOD makes a 4L version of this case that houses a Flex ATX PSU on the bottom. It's basically the Hutzy XS. It's the smallest possible ITX + GPU case with an internal PSU. Otherwise, there is no way to fit an internal power supply or an AC-DC + DC-DC into this case.
cmyk78
384
432
MN
You could probably fit a Meanwell EPP-200-12 above a lp gpu such as the 1050ti and use that to power a G-Unique.
TinyAudio
188
132
101.6*50.8*29mm (L*W*H)
It would fit for sure. I wonder if you could fab a PCI-E slot bracket so the card would sit at the top of the slot and not the bottom. You will be using a flexible riser anyway.
