Stalled Custom_MOD MINI
Revenant
1,799
2,904
USA
We can do it for you. Fill out the form. In the comment write a wish.:cool:
Oh? I've already ordered. Don't know if it's been manufactured yet. What would it look like with this slight increase in size?
Even better... since I ordered mine without the front panel logo and lighting, would there be room to put a 2.5 inch drive behind the front panel? I could probably just mount it with double sided adhesive tape.
sergiiua
Jan 11, 2017
1,156
2,057
Ukraine
www.custom-mod.com
Can fit a 5mm disk
Reactions: Curiosity
Ziths
28
Can fit a 5mm disk
Can you maybe up that to 7 or 8mm? Seems like a small change to the front panel for support for a 2.5 inch SSD. It will also cut down storage cost for my future build in your case by quite a bit.
Edit: Maybe even include some cheap double-sided adhesive
alexep7
184
139
so it turns out I won't be using this case after all, but today I got this little guy in the mail:
2.50 USD on aliexpress, might be an option for those of you who need more storage but can't use a 2.5" SSD! It's very small, about the size of 2 2280 m.2 drives next to each other. I imagine you can fit it under the GPU, for example, with some double sided tape.
Curiosity
Apr 30, 2016
754
885
34
Florida Panhandle
I've got two of those with black PCBs, I'll post here if they fit once I get my batch 2 case in. :)
W1NN1NG
616
532
Wouldn't see why they wouldn't. It's no wider than the GPU itself. But since I'm ordering the version with the psu I'll have no sata power to go along with it. NBD I've got the b250i Strix coming I've got 2 m.2 slots I think I'll survive
alexep7
184
139
don't the default g-unique units bring a sata power cable? At least my cheap picoPSU has one
W1NN1NG
616
532
@sergiiua opted without one for the ones he's bundled with the chassis since we don't have room for a 2.5 which isn't a big deal to me. I'll never use more than 2 m.2 slots so lol m.2s are too pricey
alexep7
184
139
ah, makes sense.
SATA m.2s aren't pricey, I never really understood where that idea came from...they cost about the same as a regular 2.5" SSD. If anything there is a small 5~10€ price premium, which isn't too bad...
W1NN1NG
616
532
ah, makes sense.
Well yeah sata m.2s aren't bad but you figure if I'm going to buy 2 nvmes plus another being just sata I've forked out a bunch. That's what I was trying to get at
TheHig
951
1,171
Cincinnati, Ohio
Snazzy little adapter there. I have removed the housing for a crucial mx300 2.5 and the innards are pretty small. Half the length, obviously thinner and a smidge less wide.
Unrelated. Why are you not using the Mini? Decided not to order or have one and it's a no go for you?
CC Ricers
2,235
2,558
I'm getting one of these as well. Another handy use for them is when you want to upgrade in size to a higher capacity m.2 drive and move your files to it. If your mobo lacks the support you can plug this into a SATA port and clone away to your newer drive.
alexep7
184
139
there was a small problem with my particular case (@sergiiua received it defective) which meant it had to be delayed further, so I decided to go for something else instead. I'm having trouble finding anything that compares to it that I can buy now, though!
Reactions: TheHig
W1NN1NG
616
532
Please take into account all who plan to place an order. The case will have a hole under the power connector from the G-Unique as in the photo. Thank you
So are all the cases going to use the ultra slim type 8 pin connector now?
