Stalled Custom_MOD MINI
sergiiua
CustomMOD
Jan 11, 2017
1,154
2,053
www.custom-mod.com
Dear customers and other people! Good news. Today the factory sent out the cases. I'll get them on Monday. Starting Tuesday I will immediately send them to you. Why so long? I know you are waiting for a very long time. I'm sorry that this happened. Part of the blanks was defective because I miscalculated in the calculations. They had to be ordered anew. Also the plant did not fulfill the order within the agreed period. I did my best. I wrote and called the plant every day to speed up the process. Many thanks for your patience. I will continue to work on the cases and improve them. Sincerely.
Curiosity
Apr 30, 2016
741
866
Thank you for the update, and for all the work you're putting into these!
Jonny727272
275
218
I'm not even getting one of these but your continued communication with the community looks awesome! Keep up the great work :)
Reactions: W1NN1NG
W1NN1NG
616
532
Batch #6 will be my turn! (s
till in doubt between 5.92L or 3.24L case)
I like the design of the flex. But I don't really want to deal with finding a good flex psu. I know gury does good work so I chose to go with the mini for sure
paullusty
51
he has a smaller than sfx, passively cooled internal gpu in the works too. don't know if custom mod will use it in their designs though :/
hungsu
Sep 6, 2016
Any owners of this case care to share their experience? I'm currently backing the Dan A4, but might bail out of that and get this instead if you guys have had positive experiences with it.
Revenant
Revenant Tech
1,741
2,858
I have no problem with a delay if it means higher quality. Love to see some pics though ^_^
TheHig
951
1,171
I have a build log of mine you can check out which may answer some questions for you.
Build quality is terrific.
Included riser is working great.
Build experience was challenging and fun.
Overall my experience has been very good however you need to be ok with one of two direct plug power solutions. The mini box pico or a custom order from Gury at G Unique. Both work well and if you are mindful of your component selection can work just fine. My one concern is replacing the power supply in the event of failure. You will be down while you source another. I keep an sfx or atx psu spare at all times just in case. Have for years and it has bailed me out more than once! Hopefully this helps some feel free to ask questions.
Curiosity
Apr 30, 2016
741
866
I would love to see separate magnetic side panels in the next revision.
I ordered an extra set of panels with my case, I might try cutting them and making them magnetic if I can think of a good way to mount the magnets.
