Stalled Custom_MOD MINI
W1NN1NG
616
532
Batch #4 (5 cases limit). Open for orders until MAY-10.
Ahh looks like I'll have to get on the next one then didn't realize 4 was still going on I'm waiting on a bonus check still before I can order should hopefully be here sometime this month
W1NN1NG
616
532
Do not quite understand the message
Was saying I'll probably have to wait till you do another run. I've got a bonus check coming from my work that I was going to order one with they said it will be on one of my checks by the 9th of June why I asked when the next run would be :)
sergiiua
CustomMOD
Jan 11, 2017
1,154
2,053
www.custom-mod.com
5 turn after May 10.
alexep7
184
139
How much space is there between the bottom of the motherboard and the GPU? Would it be possible to install some small heatsinks on an m.2 drive if the slot is on the bottom of the motherboard or is there not enough space?
spiffyfitz
I'd love to see how the black powder coating looks on these beauties! Personally, I like the black perforated air vents best... I think it would look so slick!
Also looking forward to seeing temps and noise reports for this beautiful case! Excellent work, sergiiua!
W1NN1NG
616
532
Now you can order, through us, a case + PSU 400W G-Unique
30cm dc-in cable with dedicated 8pin dc jack
20cm 4+4pin cpu cable
40cm 6+2pin pci-e cable(length is counted from dc jack)
400watts dell brick
May have to do this,
Revenant
Revenant Tech
1,741
2,858
400watts dell brick
Can I add that to my current order?
W1NN1NG
616
532
Also quick question about the psu does the arch daemon fit in the case or is it going to be a different unit? I'm probably going to order it custom because I'd like a shorter cable for my CPU 8 pin due to me ordering the msi carbon board and I'd like it to fit perfectly with no excess cable
alexep7
184
139
so will the arch daemon fit in the mini or do we need to have the type a or b?
Im going to order mine with completely custom length cables so knowing would be good thanks :D
can't see a reason why it wouldn't, it's 27mm in height after all
Curiosity
Apr 30, 2016
741
866
Is there space for an m.2 on the bottom of a mb since the pcie extender will be located there?
Post #305, you can actually see the m.2 drive between the mb and extension cable.
Reactions: sergiiua
