limit cube3 has similar ones.Guys, I need your help. Where can I find this stuff:
https://smallformfactor.net/forum/threads/limit-cube3-case-3-38l.1532/
maybe he can help.
For the first batch of the SLIM, too? Your cases are getting better from day to day.
I think yes, we'll use magnets in the first batch of the SLIM. We ordered magnets today. Tomorrow we'll get and test them. If all will be great, we'll change our model and start to produce the prototype.For the first batch of the SLIM, too? Your cases are getting better from day to day.Can't wait to get mine!
Thanks for info. We'll try to use magnets instead.Lian Li's stud and clips are proprietary. They use an electrical welding process to join the studs to the sheet, which isn't a capability most sheet metal fabricators will have.
An alternative is these ball stud and clips used in the Kimera Cerberus. They can be pressed into the sheet metal, which is much more common for fabricators to have.
Magnets are an awesome idea. But I think there should still be an option to screw in the panels for when you want to transport them.
Shouldn't be too hard to make the magnets strong enough to hold the panels even during a strong shock. Especially if you have small ridges that the panel can rest on so the only way for the magnets to come off is by pulling, not shearing.
can we see more pictures please! @sergiiua
10mmOn that case on the far right that we can see the back of-
If that hole above the I/O shield for the power button? How big is the hole?
hey, out of curiosity, that 1050ti uses no external power connectors, right? it uses the 75w from pcie slot through the riser? have you experienced any issues up until now?Today I received and tested Moddiy Premium Gold Plated 16x PCI-E Extension Shielded Cable Riser (30cm). Very long name
First impression - good quality and flexible enough.
Test Environment & Equipment:
- GPU: Zotac 1050 Ti Mini
- M/B: MSI H110i Pro
- OS: Win10
- Games: Overwatch
- Benchmark: Catzilla 720p
Results without riser:
- Bus Interface: x16 3.0
- Overwatch, fps: 161
- Catzilla, run #1: 14764
- Catzilla, run #2: 14766
Results with riser:
- Overwatch, fps: 159
- Catzilla, run #1: 14796 (record)
- Catzilla, run #2: 14718
Verdict: excellent, recommended!
Those cases are looking awesome. Keep up the good work ! Excited to see these build threads.
