Stalled Custom_MOD MINI
alexep7
184
139
@sergiiua do you think it would be possible to fit a 2.5" SSD in the case somewhere? Maybe with double sided tape on the inside of the side panel next to the CPU cooler, even if it blocks a little of the fan and the holes? Or is there not enough clearance between the L9i fan and the side panel?
I mean, the SATA cables would be a pain the ass to deal with even if the drive fits, but just wondering :)
EDIT: Or maybe below the GPU?
Reactions: eggDK
sergiiua
CustomMOD
Jan 11, 2017
1,145
2,043
www.custom-mod.com
Below the GPU - no.
There is about 2mm between L9i and side panel. But you can use 27mm cooler (Zalman CNPS2X, Thermaltake Engine 27 etc) :)
eggDK
78
50
I've been wondering the same thing because I would like to use my current HW, only investing in an ITX length gpu.. Maybe we'll have to try and ghetto mod our ssd's like Aibo did in the STX160
Reactions: alexep7
buLL
69
53
@sergiiua why dont a 7mm ssd fit under the GPU? I mean, GPUs are usually <4cm thick, and the case is 5,5cm. There should be something like 1,5cm of empty space... Just wondering
EDIT: sorry, I meant to ask this question on the CustomMod Slim. I cant find an option to delete the post, so answer me here if you can
Curiosity
Apr 30, 2016
724
838
Are you saying there should be room between the bottom of the GPU and bottom of the case, or between the motherboard and GPU?
Also: 100mm - 45mm for GPU = 55mm - 37mm = for cooler compatibility = 18mm -8mm for CPU height =10mm -7mm for standoffs = 3mm fo for case material.
Or at least, that's how I suspect the width is taken up by parts in the case.
Reactions: Acalanata
buLL
69
53
I meant to post this on the CustomMod Slim, not here. But as i dont see a option to delete the post, i kept it here. My mistake
Reactions: Curiosity
Curiosity
Apr 30, 2016
724
838
You're fine, friend. :)
Reactions: buLL
sergiiua
CustomMOD
Jan 11, 2017
1,145
2,043
www.custom-mod.com
We support GPU up to 45mm (with backplate), 3mm - case. Only 7mm of free space. It's ok for SSD, but we need some space between SSD and GPU.
Reactions: Acalanata and buLL
TinyAudio
188
132
I hope the grey is good. I only managed to get the purchase past my wife by saying it would match the colour of the walls in my office ;)
Reactions: paullusty
