Hello, we are working on something that can please sff users by size, cooling and looks. We are proudly present you the HORIZON by LEDGE.
SPECIFICATIONS:
DIMENSIONS (H x W x D) | Horizon 204 x 231 x 310 mm |
Bigger Horizon (Expansion part on front) 204 x 231 x 390 mm | |
Vertical Horizon (Expansion part on top) 390 x 231 x 204 mm | |
VOLUME (w/o feet, screws) | Horizon 14.61 L |
Bigger Horizon (Expansion part on front) 18.38 L | |
Vertical Horizon (Expansion part on top) 18.38 L | |
COLORS | Dusk (Black), Dawn (White) |
Sunset Red and Clearsky Blue on some parts (Optional) | |
MATERIAL | Wet Blasted, Matte Powder Coated Aluminum 2 mm (4mm on back panel) |
PANEL TYPES | Punch hole ventilated, Mesh, Tempered Glass 2 mm, Solid on right side |
Punch hole ventilated, Mesh, Tempered Glass 2 mm, Solid on top | |
Punch hole ventilated, Mesh, Tempered Glass 2 mm on left side | |
Punch hole ventilated, Mesh on front | |
ACCESSORIES (H x W x D) | 80 x 231 x 204 mm Expansion part (Optional) |
GPU CLEARENCE | Triple-Slot, Up to 270 mm with Fan Bracket A on front (Horizon and Vertical Horizon) |
Triple-Slot, Up to 302 mm with Fan Bracket B on front (Horizon and Vertical Horizon) | |
Triple-Slot, Up to 348 mm on Bigger Horizon with 30 mm thick 200 mm fan | |
Triple-Slot, Up to 353 mm on Bigger Horizon with 25 mm thick 200 mm fan | |
Triple-Slot, Up to 378 mm on Bigger Horizon without fan | |
CPU COOLER CLEARENCE | Up to 187 mm |
MOTHERBOARD | Mini-ITX, Mini-DTX |
POWER SUPPLY | SFX, SFX-L, ATX (Up to 160mm) with PSU Orientation A |
SFX, SFX-L, ATX with PSU Orientation B | |
WATER COOLING | 240 mm Slim or 120/140 mm Thick Radiator with (PSU Orientation B should be used for water cooling) |
STORAGE | Up to 7 x 2.5" hdd/ssd or 1 x 2.5" ssd + 1 x 3.5" hdd (3.5" hdd cannot be used with 240 mm radiator) |
FRONT FAN | |
200 mm fan with Fan Bracket A | |
140 / 120 / 4 x 80 mm with Fan Bracket B | |
BACK FAN | |
140 / 120 / 92 mm (140 mm back fan cannot be used with water cooling) | |
OPTIONAL | |
Up to 2 x 120 mm fan can be used on punch hole ventilated top and side panels (Rubber or magnetic screws are highly recommended) |
LAYOUT
HORIZON
BIGGER HORIZON
VERTICAL HORIZON
FAN BRACKETS
FAN BRACKET-A
FAN BRACKET-B
PSU ORIENTATIONS
PSU ORIENTATION-A
PSU ORIENTATION-B
We will produce a prototype soon. So stay tuned.
Ledge Team
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FdrXHrtyt.png&hash=87fbee48bfbf4a4f97a1ccde0cbcd93d)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FMDQCL3vt.png&hash=d40879bd543ddc8b25a04b126ad5aa50)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FQpl0RQdt.png&hash=33077859e1f962dd0b0abfd86927ba77)
HORIZON
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FbtyYHoXt.png&hash=0fb98aef4adbd24791d557ef8af4219b)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FpmC9XXZt.png&hash=2991f5f8c5a36a63fde6c7bc781ef2ef)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F8iO7byOt.png&hash=0545ad6d718befbacd7a7d80b0e9340b)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FIJQqu2Ht.png&hash=8772d40592c5ec9f81e3c85dcc39fa84)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FHqHgcoLt.png&hash=5006e59ff4e20b83d8e59686045527f8)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fm8apMXJt.png&hash=a5aa800fb705128fce37bd4e60653590)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FkyOXyG0t.png&hash=0cd64fc7d5194fd4539900302118d5a2)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FEhqAUk0t.png&hash=8dcce4bbd04220214e74fc16370fb94f)
BIGGER HORIZON
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FqFA9LvTt.png&hash=a0b45737533281799dd765d91f298bf5)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FKe9SA7Dt.png&hash=ed9dc044935aca1994f3bba5f2300c99)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FT8E6a7wt.png&hash=5132676130b7be3fa093757898f6926b)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F7lXfFAlt.png&hash=9ebb330c194f8108e9a7fbb18efadb2c)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F21n26RNt.png&hash=8107d3fe2fb6c7de0d7c1b91851e0acb)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FGTl0KqTt.png&hash=fe73644f5d80080133f4e38124f3b6de)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FOOq4OzNt.png&hash=1ef2a4c5be7d8ded6467e0fd7b9aa7bf)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FSf329elt.png&hash=c2563f9cdd9267e6f0e82b7399fd0475)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fc1kOnPFt.png&hash=76a4e182baaa6808c5b7e6eb4fd3035d)
VERTICAL HORIZON
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FognDWebt.png&hash=a411cb9017bb5dacfc6fdae092870b2a)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FqJAhWFft.png&hash=26c4c1806bec9bfda83a07db42c64c9f)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FbLU7Da7t.png&hash=b087597a57ef1d1d6f37b59e38782ec8)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fm3hEknMt.png&hash=840730173059727d89bdb6d22f34eaec)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FUN4L3bYt.png&hash=de80359df11f9876ec5692d0df5464e1)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FaNb55UCt.png&hash=20212a644c4434076892a3da67a416b3)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F6V9L8tUt.png&hash=540de253eedf93234fdd76d139beeaf9)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FnDAUFs4t.png&hash=dc279d37b4492d3b035c46ab6fe71701)
![](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FF4qSAAxt.png&hash=3a0a66379cdad3662dde43e6ac48e0fb)
FAN BRACKETS
FAN BRACKET-A
![FAN BRACKET A FAN BRACKET A](https://i.imgur.com/RIqpt5Ab.png)
FAN BRACKET-B
![FAN BRACKET B FAN BRACKET B](https://i.imgur.com/bmKtRswb.png)
PSU ORIENTATIONS
PSU ORIENTATION-A
![PSU ORIENTATION A PSU ORIENTATION A](https://i.imgur.com/UzfmUKmb.png)
PSU ORIENTATION-B
![PSU ORIENTATION B PSU ORIENTATION B](https://i.imgur.com/OsyAQARb.png)
Ledge Team
*Most of inside components are taken from grabcad.com. Thanks to creators of the models.
