Funding CASEKRAKEN FLIP H1 - Cheapest stand
You will buy stand via amazon for 45-55$? (Direct shipping 25-35$)
  • Total voters
    37
Serf1r
CaseKraken
Jan 13, 2019
101
82
casekraken.com
I'm considering this. I'd like it better without the logo though. None of my other SFF cases have branding on them (Velka 3, Salvo S402, Sliger Console), and I prefer it that way. I want my builds to look as clean as possible. I imagine it could only reduce costs for having them made as well, it's a whole step dropped from the machining process, right?
Also, a future version for 3-slot GPUs? You can really go overkill on hardware when the case is open and you don't have to worry about things fitting.
No problems, +3$ and you receive stand without logo))
3-slots gpu? You now a lot gpu with 3-slot mounting bracket? Maybe. I think about it
Engr62
127
77
I tried to order, but even when I select "English (US)" from the drop-down, it still shows price in Russian.
Serf1r
CaseKraken
Jan 13, 2019
101
82
casekraken.com
Yes, its problem. Now i work on fix, its so hard. If you have any questions - i answer. Or please use this phrase in Google "xxx roubles in dollars"
Serf1r
CaseKraken
Jan 13, 2019
101
82
casekraken.com
Some fix:
1. In release stands, pci riser will be attached to the stand
2. We decided to add ventilation holes under power supply
3. Slightly changed the position of the holes for the ties / Velcro tape
4. Changed the mount for ssd, now you can put another one
5. Bracket for 120/92mm aio (and maybe 240)
In progress:
1. Backlit logo insert
2. Branded package
philpirj
48
48
Will a Corsair SF600 Platinum work?
Amazon feedback says its power cables are ridiculously short.
