Just finished building the case. I will try to address problems that other people had and my experience with them. I had no problem inserting all of the psu screws. At one point one of the little rubber feet came off just glued it back on no problem. The motherboard standoff were seemingly not aligned properly, I only put in one of the screws and the mother board seems completely secure so I don't mind. I could have gotten in 3 of the 4 standoffs if i tried but i don't think it really matters because I will not be moving this case around. My 980 strix did not fit in the case but this is not Sergiiua's fault, i suspected it would not work. Overall this case was a challenge to build in, but i had fun and I am happy with the result.
Unfortunately no, the box she's in does come with the case thoughDid the cat in the last picture come with the case? Was there an option on the form that I missed? :-)
Once enough people own this case it would be good to have a GPU compatibility spreadsheet so people can know if their card works. A google spreadsheet would work
I made a spreadsheet but it doesn't seem to let me link it even though its in the list of allowed embeded links:
Yup, it says public on the web any one on the web can find and access it ttps://docs.google.com/spreadsheets/d/1Jvf49JYOuzRH6oWpk-mJ2GZrj4Yv_b0_-ASJXvr_4CY/edit?usp=sharing just add an h to the beginingDid you make the spreadsheet view able to the public? Just getting a shareable link shouldn't work for embedding
Yes, Party 6 will receive revision 2.2. The changes are minor. we will remove some screws from the top cover. While we solve some problems. but we believe in success!Hey @sergiiua , I noticed the 6.37l case is now in version 2.2. What is the difference from version 2.1?
Will batch 6 be version 2.2? Thanks!
is batch 5 up to date ? will it be availbe on time
