- 3D printed
- Easy to implement
- Fast prototyping of panel based SFF cases
- Gives you clean corners
3mm Material, 9mm screw point version
- Used with M3 x 8mm self-tapping screws
- Not recommended for cases above 5L.
Download STL file here (google drive link).
Questions, comments?
- Easy to implement
INTRODUCING:
MOD CORNERS
- Easy to implement
3mm Material, 10mm screw point from corner
- Technical Diagram is for 3mm material, Mod Corners can be modified for any material between 1.5mm - 3.5mm
- Recommended screw is #6-32. Can be also be used with any coarse threaded or self-tapping screws including M3 Self-taping.
ModCorner
NAME - [Material Thickness] - [Diameter of Hole]
Download Here.
Need custom size? Send me a message.
Technical drawing for 3mm material. you need to vary the corners based on your material thickness. The horizontal and vertical cut in is the length of the material you use.
Examples of cases you can do:
