Result: K1 Max v1
Back-Bone
The whole Assembly got moved down for about 10mm to get more headroom for GPU and Powerplug relocation above the Motherboard-Cut-out.
The Back-Bone had to be thickened to 8mm to adjust to the demanding thin parts between the cut-outs.
Motherboard/Riser Beams
Aside from changes on the Back-Bone, the Beams for mounting GPU and Motherboard got improved functionality and space efficiency.
The most significant change will be the elimination of the need for 6mm standoffs, resulting in an increase of 6mm playroom between GPU thickness and CPU cooler height.
Another Idea I wanted to try out was the automatic alignment of Motherboard through pre-defined imprinted corners.
So that the Motherboard can get laid into place with the screwholes perfectly aligning to the inserts on the Beams.
Mid-Bone
The Mid-Bone got split into two functional parts.
The PSU-Bone serves the sole purpose of maintaining the PSU placement.
While the New-Mid-Bone needed to be created to offload the weight-load from the GPU at an earlier distance from the PSU-Bone.
Files?
Files will be uploaded shortly after adding following missing feature:- Support Bracket for oversized GPUs to strap them into place, considering their cooler weight.
Sidepanels:
The Sidepanels are sized at 360x200x3mm so that the 180x200x3mm Sidepanels from the regular K1 can be used without further modification.
K1 Model Reached 100 downloads on printables Yay!!
in a blink of an eye it reached 120 lol from saturday to monday, looks like some printables-mod boosted the model to the front page.Another Funny Fact: I am not surprised to find out, that my main audience are Middle-aged-Males...
Shall I make a more girly themed K1 Max to get some female audience? Or am i expecting too much
Did a little overdue timelapse of the current build
I am slowly starting to assemble a screw set for K1 including Screws and Magnet kit aiming for April
