Z370 Kimera Cerberus Build
Chann3l
78
68
Sleeved the eps cable. Have to put it together and then onto the PCI-E cables.
Reactions: jØrd
Chann3l
78
68
Almost done..:)
Haha ya that last one is going to suck but since I'm planning on keeping this case for many years the psu will last a few builds anyway so it's worth making a nice set of cables. I may order some sata connectors later and make a sata power cable too at some point.
2,413
2,489
Sure does look good, plus you will make them custom length so your cable management will look much better.
Reactions: Chann3l
MarcParis
Apr 1, 2016
3,597
2,676
Same here, my cerberus-x should last many years..:)
Chann3l
78
68
Finished making the 24 pin. Looks pretty good I think. Hard to keep straight even with the cable Combs because while there is no real cross over the wires connect to the opposite side of the connector
I will get some nice final build pics this week to finish everything off.
Chann3l
78
68
Looks good, much better than the stock cables.
Thanks a lot! Pretty cheap project too. Crimp tool was 40us and enough wire, connectors, terminals and paracord to do all 4 cables was 45us. I still have a ton of terminals leftover too.
2,413
2,489
Yeah I really need to break down and learn how to do that. I am getting ready to do a build in a MI-6 which has an inverted motherboard that sits directly above the PSU so really short 24pin and 8pin EPS would be really nice.
Chann3l
78
68
Beautiful...same comment as your previous 8 pins cpu, it’s bigger than stock cable..:)
Haha ya, they really don't save too much space other than the fact that they are shorter than the stock cables. The biggest difference is the PCI e cables because the stock ones were 400 and 500mm plus the extra length for second connector. The ones I made are only 300mm
