Z370 Kimera Cerberus Build
Chann3l
78
68
I have been doing custom watercooled builds for the last 5 years in fairly large cases. This is my first SFF build. I wanted to cram as much power as possible into a small enclosure. I am not a fan of AIOs so I've decided to go with air cooling for this build.
Case : Kimera Cerberus
CPU : 8700k
MOBO : MSI Z370M Gaming Pro AC
GPU : MSI Reference 1080 Ti
Memory : 32GB DDR4 G.Skill Trident Z
PSU : Silverstone SX650-G
Cooler : Noctua NH-C14S
Storage : 256GB 850 Evo, 250GB Samsung 960 Evo NVME
Fans: 3x Noctua NF-A14 140mm pwm 1x NF-A9 92mm pwm
Reactions: royalba94
Chann3l
78
68
Big photo dump incoming
Fan had to be moved to the top for ram clearance
Cooler Installed
lol, artsy b&w photo with 960 installed
Cerberus compared to Thermaltake V21
Beautiful blank workspace
All the panels look this nice. Not one imperfection
Mobo installed
Zero issues with the IO shield fitting
Just enough clearance for the side bracket in this configuration
PSU mounting was very simple. The mounting bracket also has a hole for the front panel cables
Went a little overboard with the 140mm fans. Have the 850 ssd mounted behind the PSU but won't be able to add another unless I remove the front fan as the power connector is slightly too thick to fit. I did test fit my 1080 ti and there is plenty of room as expected but I can't install it until my ram arrives.
That's it for now
Also, excuse the grainy photos, iso was set too high on my camera
Chann3l
78
68
Still waiting on the ram to arrive but I wanted to get Windows installed so I've installed 16GB of gskill tridentz for now.
The lower height of these modules allows me to use the front fan as a second CPU cooler fan. I may just buy another 16GB of this instead of using the dominator platinum. Undecided.
Definitely not the final look. Still need to make my custom PSU cables. The flat ribbon cables are not the best looking.
That's is until I either get my other ram, or my cable making supplies get in.
MarcParis
Apr 1, 2016
3,597
2,676
Thanks again for all these photos.
What about psu noise? I know it’s not semi passive, but what about global experience with it?
Chann3l
78
68
Haha no worries, I figured the pictures might be able to answer other community members questions if they are thinking of jumping on the Cerberus boat. I don't hear the PSU at all. The 92mm fan I think makes a big difference over the 80mm that people said was quite noisy. I have all the case fans set to pwm with the default fan curves and unless I'm doing some gaming, rendering or other CPU intensive tasks, everything is near silent overall.
MarcParis
Apr 1, 2016
3,597
2,676
Thanks for your feedback..:)
Reactions: Chann3l
Chann3l
78
68
Hmmm, why is your CPU cooler's front fan exhaust pointing out like that, I'd imagine pushing air towards the heatsink would be optimal.
Because it acts as an additional exhaust. Otherwise it is just a single 92mm fan exhausting hot air from the case. I also didn't want hot air blowing onto the ram and vrms.
Performance is actually really good in this configuration
With 1.26 volts at 4.8Ghz.
Also dust, I didn't want to have to filter the side
MarcParis
Apr 1, 2016
3,597
2,676
Completely agree, that’s the best overall airflow. Like many sff, exhausting hot air is the main target, especially to protect non monotired components, vrm, ram and also psu..:)
Cable making supplies are here, just waiting on my crimp tool.
Good luck for crimping..:)
Reactions: Chann3l
Chann3l
78
68
Ya the crimping is not going to be fun. I've sleeved my last two PSUs and used Paracord so that part will be a breeze but I've never made cables. I bought the crimp tool from mainframe customs since they claim to have machined to work better with 16 gauge wire
Reactions: MarcParis
