Yeah I might not buy groceries for a week, but case itself...Decided to build myseld a NFC S4 Mini system. Even tho i am on a budget. The case is worth it to buy the parts separately.
Some pepper and salt and it should be fine.Protip: The cardboard box it comes in is edible.
Sounds very appetizing, would let my girlfriend taste first tho.You can even boil it to soften the glue if needed -makes for a soup with a lot of fiber.
Just out of curiosity, i see alot of people having 3d printers. Is it worth it to actually get one not for business? But just have some fun with it.3D printed a 50mm to 60mm Fan Adapter. Not the first print, but only because the first time the filament broke. PLA was too dry. This is in PETG on a glass bed, no adhesive. 2mm layer heightGonna have to expand the 50mm fan mounting point cutouts and adjust the final height.
Glad it turned out as well as it did, it's actually fairly heavy.
In my opinion? DefinitelyJust out of curiosity, i see alot of people having 3d printers. Is it worth it to actually get one not for business? But just have some fun with it.
Do you recommend me sometething? Just wanted to create some decorations from a game to mount on my wall. I have no knowledge with 3d printing.In my opinion? Definitelysomething entry-level won't set you back much, but of course if you start to like it you'll eventually want something even better. It's like building a computer
Best to do some looking into itDo you recommend me sometething? Just wanted to create some decorations from a game to mount on my wall. I have no knowledge with 3d printing.
Thanks! Definitely gonna check it out.Best to do some looking into iteverything from build volume to construction quality, if it has a heated bed, if it self levels, if it accepts or requires modification after purchase... For around $200 you can get a Monoprice Select Mini. It has a small build area and requires manual leveling, but would probably be just fine for small things. Also comes pretty much ready to go, no assembly needed.
Oh man :/
