Wesena ITX4 v3 - Hackintosh
Nwkrep82
41
I'm new to this site, but here is something I built a few months ago..
CASE
- Wesena ITX4 v3
CPU - Intel Core i3 6100
MOTHERBOARD - Gigabyte GA-Z170N-WIFI
MEMORY - Crucial Ballistix Sport LT 8GB 2 x 4GB DDR4-2400
CPU COOLER - Noctua NH-L9i
CPU COOLER FAN - Noiseblocker NB-BlackSilentPro PE-P 92mm x 25mm Ultra Quiet PWM Fan - 1800 RPM
CASE FAN - Noiseblocker NB-BlackSilentPro PC-P 80mm x 15mm Ultra Silent PWM Fan - 2500 RPM
POWER SUPPLY - picoPSU-160-XT (custom sleeved), 160w output, 12v input DC-DC Power Supply (192w AC-DC Power Adapter, 12v 16A)
STORAGE - SAMSUNG SM951 M.2 128GB
GRAPHICS - MSI N750 TI-2GD5TLP w/retrofitted cooler from EVGA Geforce GT 730 2GB (low profile) - cooler and PCI bracket PlastiDip black for a stealthy asthetic.
OPERATING SYSTEM - OS X EL Capitan
Ceros_X
748
660
Very clean looking build! I like the black motif!
Can you go into more detail on the cooler swap and how you figured out they were compatible? Also the plastidip came out good. Anything special there or just keep peeling it off until it works?
Nwkrep82
41
Thanks!
I didn't actually know if the cooler swap would work. The mounting hole patterns looked the same, so I just gave it a shot. I bought both cards. The heat sink from the GT 730 bolted up with no issues to the 750ti. I did, however have to modify the fan connector because they were different sizes.
Nothing special with the PlastiDip. Just a few light coats and that's it.
CC Ricers
2,233
2,556
Very cool build. I had a Hackintosh once with the good ol' Intel Bad Axe and Q6600 and would like to build one again. I especially like the use of the GT 730 fan to make the 750 Ti single slot.
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Very clean build !
I have the same case and same GPU and the latter tends to get very hot and noisy...
MarcParis
Apr 1, 2016
3,629
2,722
Nice setup..those pico psu/hdplex 160xt inspire me for my next desktop/storage setup (next year project, probably based on Ryzen/Vega APU..:))
lac29
67
40
Damn this is cool. I really want to see if I can build and install dual booting system with Win10 and MacOS in a SFF.
Nwkrep82
41
Some more shots...
Changed from the PicoPSU-160-XT to the HDPLEX 160W DC-ATX...
ASL GTX 1050 Ti Battle Flag installed...
ASUS ROG STRIX Z270I w/7700K all powered up (yes, that is a RGB vandal switch wired to motherboard RGB header)...
I still have other things/mods to do before its 'complete'...LOL
AleksandarK
/dev/null
May 14, 2017
703
774
Where did you get RGB vandal swith? What model is that? I have seen some RGB switches, but they do not look good as yours.
robbee
n3rdware
861
1,350
Awesome to see the ASL 1050ti in action! Would you mind sharing your thoughts in regards to the termals and noise?
CC Ricers
2,233
2,556
Awesome to see the ASL 1050ti in action? Would you mind sharing your thoughts in regards to the termals and noise?
Same here. Also curious about power draw during gaming (I'm assuing you're gaming in 1080p but doing non-gaming stuff in 4k?)
Reactions: AleksandarK
Nwkrep82
41
I still have some testing to do, but with cover off, in a room about 73F (22C) I've seen the card get as high as 71C with stock boost in the mid 1700 (before downclocking as temps increase). I've even had it in the mid 1800 with a +100 on the GPU.
Of course with Pascal, those numbers dynamically change with temp, load. power limit, etc.
I'll have more detailed numbers soon along with some noise level testing (with/without cover).
Could I get link for that RGB switch? Looks amazing on your build? Also, is the size 16mm?
The switch is 25mm from http://www.performance-pcs.com/ppcs-anodized-illuminated-switch-black-25mm-momentary-rgb-ring.html
