Description
This semi-custom PSU is great for black-themed FlexATX builds and should be a great alternative to the SFFTEC ENP-7660B Pro, which is also black but has extremely long delivery times and a lot of the time doesn't deliver at all. A lot of people have been complaining about the SFFTEC ENP-7660B not delivering, which is concerning. The Velka edition is $139.99 when sold individually, and only $100 when bundled with a Velka 3 rev 2.0 or Velka 5 rev 2.0, making it cheaper than the original 7660B sold by Enhance on Amazon!
Specifications from the website
A semi-custom version of the ENP-7660B with a black powder-coated casing and shortened black cables. Makes cable management a breeze in small cases.
Available for $100 only if bundled with a revision 2.0 Velka 3 (not RL) here or Velka 5 case here. This discount is limited to 1 power supply per case.
Warranty: 1 year
Links
Main link
Velkase ENP-7660B VK
Other links
SFFTEC ENP-7660B Pro (Buyer beware!)
Enhance ENP-7660B
- 2x 6+2 pin VGA, 1x 4+4 pin EPS, 2x SATA, 1x 20+4 pin MB connectors
- Input voltage range: 100-240 V
- Output power: 600 W continuous
- High efficiency: 92% efficient at 50% load
- 24 pin MB: 250 mm
- 8 pin EPS (for CPU): 350 mm
- 8 pin VGA (for graphics card): 250 mm + 50 mm
- SATA: 200 mm + 150 mm
Warranty: 1 year
Links
Main link
ENP-7660B-VK 600W Flex ATX PSU
Description A semi-custom version of the ENP-7660B from Enhance Electronics with a black powder-coated casing and shortened black cables. Makes cable management a breeze in small cases. 80 PLUS Platinum: 93% efficiency at 50% load, 92% average efficiency 2x separate 6+2 pin VGA, 1x 4+4 pin EPS...
www.velkase.com
Other links
Enhance ENP 7660B 600w Flex ATX 1U Power Supply l Black Silent ITX Platinum PSU | SFFTEC
Enhance ENP 7660B Pro is a custom 600w Flex ATX power supply developed by SFFTEC. This powerful 80+ Platinum PSU is manufactured and customized by Enhance with a quiet fan, black short cables, and dark body. It fits neatly in most SFF PC cases, and will have a very limited stock
www.sfftec.com
