Damascus
548
383
If you think this is funny, you should come see the degenerate comments people make on my Reddit posts. They will leave your stomach hurting from laughter. Many call this case nothing more than a "folded piece of metal".
With that being said, Velka M will probably be my first and last case to be sold publicly. It's too cheap to appeal to people who would rather have a pretty metal and glass hotbox for a computer case and too expensive for those who don't see the benefit of something like this over a cardboard box.
Your greatest mistake is massively underestimating how much people care about side panels. The current aesthetic of high end PCs (the market for a $100+ case) is clean lines, rgb and glass. Having mesh as the only initial option was dropping a brick on your foot tbh.
VELKASE Michael
VELKASE
711
876
That's understandable but I make computer cases, not furniture.
Damascus
548
383
The balance between form and function is why the ncase, zaber, dancase and S4m are massively popular. If the overwhelming industry trend is glass or perforated solid panels with an abhorrence towards mesh and you come out with a case that has tonnes of potential and a complete 180° turn from what people want (again, according to the market) it will have a hard time selling.
Reactions: DKsystem
VELKASE Michael
VELKASE
711
876
Yeah, exactly, which is why I'm going to stop making them. There's no point in going on with this project when literally no one cares about product functionality. That is not an exaggeration. People don't seem to understand how limiting perforated sheet metal is for airflow in cases of this size. The mentioned cases take up substantially more space.
This case has several unique selling points, but so few are willing to go as far as read about them after seeing a picture and concluding "oh, this case has edges and bends and ventilation? That's a no go for me."
One thing that I might try to do is create another version of the case and price it really low and make shipping really cheap. In the same package, include both mesh and sheet metal side panels to let users compare the options themselves.
Damascus
548
383
This would probably do the trick, especially if you show off the side panels. On a side note, you could try something like skylots for the side panels, you have a decent amount of airflow with them while keeping the solid side panel.
Damascus
548
383
I can already see the "S4 mini clone" complaints coming in.
Well, at least you can say you aren't like custom-mod. I'm pretty sure Josh has said it's ok to use them in the past, though a message his way would clear it up.
I hope you can at least sell your first batch, have you thought of sending a review sample to one of the mid-large tech tubers?
VELKASE Michael
VELKASE
711
876
Three videos featuring/ reviewing this case should be up by around mid to late January on YouTube. Two of those creators have around 10K subscribers each and one has around 30K subscribers.
Thanks for waiting out my rant haha.
VELKASE Michael
VELKASE
711
876
Thoughts on this pattern?
(ignoring the small holes on the perimeter)
VELKASE Michael
VELKASE
711
876
Functional and simple, and I imagine you already have a good setup for punching the holes so that makes it a bit easier.
Edit:
Reminds me of the zs-a4m, I like it
All holes are laser cut so they can easily be changed
ZombiPL
DR ZĄBER
Apr 13, 2016
238
762
Thank you for your input.
The graphics card is secured internally. It does not move during transport. I am considering adding a mount to the outside as suggested.
With the correct power supply choice, it is not a drawback in terms of silence. For example, I am using an FSP Group 500W Gold power supply. The Noctua fan on an NH-L9i/a is more audible than the power supply fan regardless of the fan curve at both idle and load.
+1 for GPU additional fastening
As for the PSU, I never heard about silent flex PSU with proper efficiency. Maybe there is a solution for that somewhere, but I predict it will be something like a high power PSU with passive cooling option (for example 800W PSU for a 300W system and low fan ramp). The main problems with quiet flex PSUs are probably poor availability and lack of other options. It means, if you say that there is a manufacturer for quiet flex PSU, then can you mention one ot two more, so people would have options to choose from? There is nothing worst for a design than closing it for only one supplier for its parts. I really would like to see some tests of those silent flex power supplies, because i had contact with many of them, but none were at least as silent as standard sfx PSUs.
It is not high.
-PCI-E risers cost as little as 20 USD
-The total cost of this case for a US buyer would be 135 USD. For a European buyer, it would be about 170 USD (150 EUR) after import fees. That is still less than comparable cases.
For small production run the price may be justified by a very small amount of manufactured units. With bigger production you should ask your subcontractors for better offers, so you could lower the final case price and get more buyers.
-The fact that there are no welding points, punched holes, rivets, plastic feet, rubber plugs, etc means little. The demand for a product, not its cost to manufacture, largely determines its price. The product's manufacturability determines whether it is viable to produce and sell such a product at the price that people are willing to pay. Over-engineering a design by welding, making unnecessary components, etc cannot be used to justify a higher price.
That is not fully true. Everything depends on where you are with your product (in time). At a place where you are with your case, to sell it at a certain price you have to justify it (clarify to you clients why this product is worth their money and why it is better then other similar products they can buy for the same amount). If not, you will not build a proper demand for your product.
-The mesh replaces the side panels. Just because it doesn't have sheet metal on each side doesn't mean that the components inside are not protected. It actually feels fairly solid when attached to the case. When you use this case, the fact that the side panels are mesh is not something to cross your mind because the case looks like a plain black box (unless if it is right in front of your face for some reason). Either way, I might introduce sheet metal side panels soon for those who want them.
Tbh I did not notice that this mesh is going to be permanent (only for prototype or something like that...). If you want it that way, then why you just not add some steel tapes on the sides and place a proper magnetic dust filters, like those from www.demcifilter.com?
First, you do not the know my production costs. Second, this is already the least expensive case that uses brushed and anodized aluminum of a decent thickness. My batch size is much smaller than 50 units.
Ok. High price in your case is justified by low production run. Got it. I thought there is something else (in your design) which generates high costs.
If you would like, I can head over to your case discussion and ask some thought-provoking questions. For example, why is a case produced in the hundreds priced as high as it is, at the same time forcing any buyers to wait an undetermined amount of time for availability?
Please, do it! I invite you to participate in our project threads. All those questions were asked hundreds of times and you can find answers for them.
What is more, Sentry is a community project, so current version 2.0 is mostly redesigned by people who already bought previous version. We are talking about problems, possibilities, improvements, costs, prices, timelines all the time. I don't remember other case project in which feedback from people had such big influence on the final design and in which people knew so much about its manufacturing costs. Our daytime jobs are somewhere else so we are not scared to give answers.
I cannot believe the amount of negativity this design has received about its price. All of other design elements, yes, please go ahead and criticize them so that they can be improved. But criticizing the price? Why choose this case to criticize and not the $200+ cases that use the same or cheaper materials and have been made in the thousands? And no, the mesh was not a cost-cutting decision. Not to point fingers, but NFC, if I recall correctly, sells power buttons for $25 that can be bought for $5-15 elsewhere and no one seems to be complaining about that. They are not doing anything wrong because the demand determines how a product is priced. However, when there are so many examples of high profit margins in this market, for some reason my design is being criticized for its price despite the fact that it is less expensive than any comparable offerings and the fact that I am literally NOT MAKING MONEY OFF OF THIS.
I think you overreacted a little bit. If you felt attacked by my questions, I am sorry for that. That wasn't my point. In the world where something like 95% of pc cases production comes from China, you are making your cases in the USA like Josh used to, and I thought you might be a good source of proper information about real costs of production there. That's why i asked those questions.
I think if you come to technical forums you should be prepared for such questions. If you find people complaining about something and you can't or don't want to defend your decisions properly, then you should stay on reddit. In forums like SFF or [H]ardForum we are talking about every aspects of design, including its improvements, flaws, manufacturing costs, etc. If people will see that you came here only to talk how good is your design, and you will not going to listen to them or give them answers why you did this and this in that way, or if you can make this and this better or cheaper, then they will think that you are only making an advertisement of your product. You won't build a demand that way. Please also visit Sentry, A4-SFX, NFC, Ghost threads and check if there is no complains about costs and prices. I can assure you are not the only one who have to face those questions and with prices $200+ there is way more complaints than you have to deal with :D
VELKASE Michael
VELKASE
711
876
Demcifilters don't work as well and are prohibitively expensive, even in bulk. The mesh is made from some sort of cloth instead of steel, which can easily droop, rub against fan hubs, and generate noise. Fan clearances would have to be increased by several mm to avoid this problem. It is also very easy to get fingerprints on the frame.
As for where the cases are made: they are actually made in China and not the USA. However, I follow the manufacturing process personally. The consistency of quality is better than anything I have seen from North American manufacturers.
ZombiPL
DR ZĄBER
Apr 13, 2016
238
762
10 mm diameter
So you are on an edge: Your coins won't fall in, but you can put a finger through those holes (however without big injuries). I think it is a good dimension. You could make a nice pattern out of those holes...maybe some unusual shape.
VELKASE Michael
VELKASE
711
876
I may reduce the size closer to 6 mm so that there is a clearer functional and visual difference between the mesh and hard panels. That way, the mesh can be used to achieve high airflow, dust filtration, and the hard panels can serve as protective covers.
ZombiPL
DR ZĄBER
Apr 13, 2016
238
762
If you go with 6mm holes, you will need a lot of them to keep a proper ventilation area. Also if you will keep cutting them with laser, then the price for those panels will significantly increase. With 4-8mm holes you should start thinking about using punching machine.
VELKASE Michael
VELKASE
711
876
The fact of the matter is, proper ventilation cannot be achieved by perforating sheet metal at all when dealing with a case this small with such tight clearances. The mesh has about an 80% open area, and only about 40% open area is achievable with perforated sheet metal if the holes are large.
The price will increase, but that seems to be what most people want.
VELKASE Michael
VELKASE
711
876
The side panel is from the first Velka M prototype. It was a really loud and hot case.
