Log Velka 7 watercooled 240mm 3060ti
crackerlegs
49
81
This is fun to look at. I recently dived into Velka 5 V1.1 and 7 builds and am keen to buy a case once the revision comes out with the V4.0 riser. Interested to see your progress with this!
Will there actually be any benefit to this rather than running on air?
FiftyFifty
64
124
Running it on air with cpu and gpu both running full power can get pretty noisy. Will post temp and rpm results when finished with build.
everett
Sorry for the double post, also just saw the video; there is absolutely no room for anything else lol
Vir
71
61
What would be the required gpu thickness to pull this off? I am seriously considering copying your build.
FiftyFifty
64
124
There is around 62mm of space on the gpu size. But you have to take space for fans into consideration so you do the math :)
FiftyFifty
64
124
Have run some benchmarks and here are the results.
Cinebech R20 + Furmark
CPU 11400
120W - 70C
GPU 3060 Ti
200W - 56C
So total 320W water temp 45C with fans running 100% 1850 rpm.
While gaming i run the fans slower and i am really happy with the noise, its very silent.
Reactions: Valantar
CubanLegend
Steely-Eyed NVFlash Man
Dec 23, 2016
827
1,008
smallformfactor.net
amazing build, question.. why watercool an 11400? why not go full on to an 11600/k? you have the cooling and the PSU for it. ;) it just seems like the 3060ti is a PEAK card, nearly a 3070, but the CPU isnt quite on it's level?
FiftyFifty
64
124
Thanks. Don't feel like I need a faster cpu when game at higher resolutions, the gpu is bottleneck anyways.
FiftyFifty
64
124
Here are some pictures of the finished build.
Tuscany
159
63
@FiftyFifty can you please give a bit of inside on the TX240 sanding process?
I don't have many tools, like sander, so I want to get an idea if I can do this with whatever I have.
FiftyFifty
64
124
I just used a dremel on the side you can see in the picture. The other side is untouched.
