Hi.
This is my new project I am working on. Haven't really had much time lately but trying to doing little by little everyday.
Will try to update as much as possible, still a long waaaay to go.
HARDWARE
Here is how the radiator will end up.
Front view.
Had to move the GPU up. 3D printed bracket i found in the Velka thread (thanks to whoever made it).
This is the radiator sanded down to make as much space as possible. Gonna spraypaint it black when finised.
New mount idea for PSU.
Have to rotate the PSU to fit the GPU.
HARDWARE
- Case: Velka 7 2.0
- Mobo: Asus B560i
- CPU: Intel Core 5 11400
- CPU Block: Alphacool XPX 1U Waterblock
- GPU: Gigabyte 3060ti Eagle OC
- GPU Block: Bykski Waterblock + Custom 5mm acetal top
- SSD: WD SN750 1TB + Crucial P2 1TB
- PSU: Corsair SF750
- RAM: Corsair LPX 2x8GB 3200 CL16
- Radiator: XSPC TX240
- Fans: 2 x Noctua A12x15 Chromax
- Riser: Louqe Cobalt Gen4+ PCI-e Riser
- Controller: Aquacomputer QUADRO
- Pump: Laing DDC 3.2 PWM + EK DDC Heatsink
- Tube: Alphacool EPDM 13/10
Cut hole for motherboardFit the PSUwith new internal power cableFinish the GPU top plateMount the radiatorMount DDC pumpCustom PSU cablesSpray painting the radiator blackMaybe need new mount for DP/HDMI cablesProbably need to sand down the fans- Probably a lot of other things along the way
Front view.
