This case is not available yet; this is just an idea.
Builds featuring hardware along the lines of a Ryzen 7 2700 and RTX 2080 TI may be possible in a 4.6 liter case. If made, this one will be the smallest brick-less case for full size graphics. Cases of a similar size currently support either ITX size (170 mm) graphics cards with an internal power supply or mini size (~220 mm) graphics cards and require the use of an external power brick.
It will feature a back-to-back layout where the graphics card is behind the motherboard, and the power supply is adjacent to the motherboard on the CPU side. Two slim 80 mm fans can be mounted as well. All visible faces will likely be free of screws.
Specifications
Possible external dimensions: 270 x 92 x 184 mm
External volume: 4.6 L
CPU cooler height: 38 mm
Graphics card length: 267 mm
Cooling: 2x 80 mm fans
Power supply: Flex ATX
Materials: Steel, Aluminum
Below are some early concept renders. The internal structure is not fully pictured.
Specifications
