Mind you it was a 1080Ti mini.
the 1080ti mini consume the same as a normal 1080ti
All the 1080s i've seen have one 8 pin connector. From what I read an 8pin delivers 150W. The TDP of a 1080 is 180W, so it must be getting 30W from the PCI-E riser in JayTwoCents build.
The EVGA 1080ti has a 8pin and 6 pin for a total of 150+75 = 225W. The TDP is 250W, so it only needs 25W from the riser.
If the riser can provide 30W to the 1080, why can't it provide 25W to the 1080ti? something doesn't add up.
I was skeptical of the 500W 40A PSU in Jay's video causing the 1080 Ti issues. So I suspected the riser. But I didn't consider that the regular 1080 would be pulling more.Who said it can't? I'm confused.com.
Anyway a 600w PSU should handle a i7 6700k, 1080Ti etc. config so no need to panic.
Plus i think you are confusing TDP with Wattage consumption. They are two different things.
Yeh I think we're good to go. It was probably the PSU or something with Jays build alone.I was skeptical of the 500W 40A PSU in Jay's video causing the 1080 Ti issues. So I suspected the riser. But I didn't consider that the regular 1080 would be pulling more.
Cryorig are bringing out a copper C7. with a fan swap this might be just as good.On another topic: MAYBE a SOLUTION to the CPU-Cooler/Heatsink problem
So you guys know that the NH-L12 from Noctua (Louqe's recommended air-cooler) currently is not available...
so were left with the:
--NH-L9x65 which is also less than ideal because it creates more noise and turbulence since its basically at the side panel (2mm clearance)
--NH-L9i which is less performant than the x65, but doesnt have the space problem!
--And some other coolers that i cant really say much, except that i have heard that they're(cryorig, bequiet etc.) usually less performant in most categories.
AND since the new NF-A12x25 on which they approx. worked 5 years just came out, I thought:
Maybe you can replace the
NH-L9i's 92mm cooler with the NF-A12x25 using an adapter like these:
https://www.google.de/search?q=120+...r3bAhXENJoKHUt3ClcQ_AUICygC&biw=3400&bih=1303
would appreciate hearing your thoughts
thank you
thank you
@PaChalski What kind of GPU cooler do you recommend a blower style cooler (like a reference card , founder's edition card ) or an air cooler? I've heard many people say that blower style coolers are more suitable for SFF cases ( like this one ) but your GPU compatibility list is full of air cooled cards and even your air cooled build on YouTube has a ASUS GeForce GTX 1070 Strix Gaming OC 8GB an air cooled card. So I'm confused as to which type of card is more suitable for this particular case. If it's an air cooled card does it thermal throttle and increase the temps of the other components in the case?
Nice. What was/ is the psu fan speed like? Is it noisy. I currently have a 700w sfx-l but i am thinking of getting one of the new sfx 650w units from EVGA or Silverstone when they hit the market. Wattage is probably overkill but i like having head room so the psu doesn't have to work as hard, and therefore fan speeds are likely to be lower, with equals less noise. For reference i'm using a 1700x @3.85mhz and a GTX 1080 FTW.I have had a 1080Ti and Ryzen 1700X running on an SF450 for over a year with no problems whatsoever, peak power consumption was ~420W when I had everything at 100% load for crash testing (I thought I was crashing due to power consumption, not the case). Then again I run mine at stock/factory OC. I would bump up if there was an OC involved.
the slackbot still says it will ship out on july 10th. no other news to speak of. if you're a backer/slacker, you should get an email from louqe when everything is finalized and ready to go.Any news from Loque?
Hello,
I am considering my first SFF case (main reason being potability in a backpack).
I tried to read some of this thread but is quite long and also there have been many changes over the months.
If someone could help me with this questions would be very nice!
1) are there any Dust filter available? (as I live in a very dusty place)
2) the Hats with USB ports are already available?
3) is there any simple cooling setup involving the top/bottom Hats and extra fans? (I live in a very hot place so it could be nice to have extra cooling, if it's easily removable along with the Hat when I need to travel)
Thanks
