I always intended to write a build log for my Ghost S1, but I never got around to it the first time around.
However, my list of pending modifications has been snowballing ever since the announcement of the 65W TDP Ryzen 3700X.
I figured this would make a good opportunity to write a rebuild log.
I originally pre-ordered the case early may last year, and after 8 long months of waiting it finally arrived on my doorstep.
It was from the first batch, so I was a little bit anxious unboxing it, not sure what imperfections to expect.
You often hear SFF enthusiasts say there is no such thing as an endgame case. While I do agree - If there was such a thing, for me, this case would be it.
The build quality is immaculate, and the anodized olive green (pangaea) finish and copper top grill sets it apart from all other cases i have owned.
The case and its condition was perfect apart from a minor imperfection on the copper grill.
I had already sourced all the parts in time for the delivery of the case, even the custom sleeved cables.
Since I had all the parts and had been planning out this build for the past 8 months I was able to assemble the build in a matter of hours, if not minutes.
The build does run a little bit hot, but overall I'm very happy with this build, though i've been having some stability issues with the RAM.
They do not clear memtest passes on their rated speeds (hardly any speeds for that matter), so I will RMA these in time for the rebuild.
Pangaea finish. It's really hard to do the finish justice - the case colors changes heavily depending on the lighting conditions.
The assembled build. Custom cables courtesy of pslate.
Top view. Everything fits nice and snug.
Despite the build running hot I've been itching to upgrade to an 8 core CPU ever since the Zen 2 launch.
I am planning to use this upgrade as an opportunity to work on the temps - hence the rebuild.
At the time of writing this post i have the following to-do list:
Parts & mods:
First things first - I need to order up some hardware.
On the shopping list is the CPU, thermal paste, new fans and case feet.
I will also need to pick up a new kit of RAM. I'm considering picking up some CL14 B-die to go with the CPU, depending on current pricing and availability.
Original specifications:
The APU on this chip is impressive to say the least!
- Mobo: ASUS Strix B450-I
- CPU: AMD Ryzen 2400G
- Cooler: Noctua NH-L12
- GPU: GeForce GTX 1080 FE
- Memory: 16GB Corsair Vengeance LPX, 3000MHz@CL15
- Storage: 1TB Samsung 970 EVO SSD
- PSU: Corsair SF450 Gold
Parts & mods:
Ryzen 7 3700x installation
Replace the 92mm fan on the NH-L12
- Will be replaced by a 120mm NF-A12x15 PWM fan
Remove RAM heatspreaders
- The RAM will not fit comfortably under the modified CPU cooler with the heatspreaders, so they'll have to go.
Install case fan & test intake/exhaust configs
- An additional NF-A12x15 will be installed under the PSU.
- Because my FE GPU has a blower-style cooler, I'm not sure if exhaust or intake will be best.
I will likely do some testing to determine the optimal configuration, but any input would be appreciated.
Replace the case feet
- The stock case feet has the case sitting really low, heavily restricting airflow.
I will replace the feet to elevate the case further and give more room for the new case fan to breathe.
GPU mods
- The heatsink on the 1080 FE is covered by an acrylic window in order to force the card to exhaust towards the back.
It will be removed in order to improve temps. - I'm considering repasting the GPU with Thermal Grizzly Kryonaut.
Though it was already repasted with NT-H1 last year, so I might skip this step as it will likely yield negligible results.
I/O-shield removal
- I'm considering removing the I/O-shield for adittional airflow, depending on the case fan configuration.
Any input on this would be appreciated.
Benchmarks
- Benchmark the build before, during and after the rebuild.
- Ideally I want to do extensive testing in order to document the results of the mods in multiple configurations.
However, as this will be time consuming I might not be as thorough as I'd like.
