Chrip
87
51
Yea... I didn't buy that conclusion. Even if he was pulling 400W (which is highly unlikely with a stock 1080 Ti FE), there is still plenty of headroom on that 90% efficient PSU with a 40A 12V rail. The card expects 75W from PCI-E and not all riser adapters can do it, some have 12V Molex connectors. I'd certainly prefer if his PSU were the cause, but without someone testing a 1080 Ti or Vega I'm skeptical.
Here is the supported GPU list, 1080 Ti and Vega 64 are on it:
https://www.silverstonetek.com/downloads/PSU/GPU-supportlist.pdf
Interesting. Thanks for asking the question then. I certainly hope the riser isn't the issue as I plan on buying a 1080ti
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
There was a whole debacle about risers needing to carry power and stuff - long story short is that virtually all modern cards will draw nearly all of their power over the dedicated plugs on them.
Reactions: Chrip
Chrip
87
51
So nothing to worry about if I get an EVGA 1080Ti SC2 and a 600W corsair PSU?
deagle
Does that apply to cards with without dual 8-pin connectors? 6+8 pin maxes out at 250W.
Biowarejak
1,744
2,262
Does that apply to cards with without dual 8-pin adapters? 6+8 ping maxes out at 250W.
Yes:
The peak draw wouldn't hurt anything, and even the max during torture is below the rating (and those connectors will tend to be rated below their capability).
Reactions: SeeFiFo
deagle
What happens if you extend the FE's 250W power limit in Afterburner? Do the connectors provide more than they are rated for or does the card draw from PCI-E?
Biowarejak
1,744
2,262
Well happens if you extend the FE's 250W power limit in Afterburner? Do the connectors provide more than they are rated for or does the card draw from PCI-E?
They provide well above their rating. It can draw over PCIe if it's configured to do that, but after the RX 480 issue it's less common now.
Reactions: owliwar and SeeFiFo
deagle
I don't want to beat a dead horse. I just don't see how a 6+8 pin card doesn't pull from the slot when told to go 20% over the limit of power supply connectors' spec. The OEMs would be gambling on power supplies providing more than the spec. I'll have to do some more research.
Biowarejak
1,744
2,262
Go right ahead :) if I'm wrong I'd love to know. It's a good question, I think at some point I'll design a PCB to test it.
Chrip
87
51
I just researched some stuff and it looks like the 8pin provides 150W, and 6 pin provides 75. That is a total of 225W. The EVGA 1080ti SC2 is rated at 250W. is the other 25W going to come from the PCI-E riser? how much wattage can this riser provide?
Sorry to keep going on and on about this. Im just trying to understand how this all works.
2,696
2,825
I have seen tons of 1080 Tis in Dan A4-SFX and Sentry builds and they both use riser cables, so I am guessing it is not a problem.
The PCI Express 3.0 provides 75 watts of power, a quality riser will provide that or close to it.
Bangle
147
112
You are right Riser cables are fine to use. Had a phanteks shift which uses a riser. worked just fine. BTW that was one of the worst cases I've ever purchased.
Bangle
147
112
How come? i cancelled my phanteks shift order in favor of the ghost s1, this is kind of reassuring to hear.
Where to start:
1. The glass panel on the graphics card side doesn't let hot air to escape. My 1080FTW card got pretty hot and the fans always ran even with the least stress placed on in. I would only recommend a blower card.
2. If you use a SFX-L PSU there's little room (about 1.5cm gap to route your cables towards theMB and GPU (I think there's a few youtube vids that point this point. The 24 Pin connector is especially difficult to tread through the gap; and i would recommend doing the cabling 1st before you screw the psu in.
3. Poor SSD location. Hard to easily remove and put back when the PSU and MB are in.
4. The little drop down cable management tray flips down and always stays down as the tray isn't wide enough to accommodate all your cabling and the blue usb case connector. The magnet used to resist the pressure of the cables is too weak. Plus its made of the cheapest plastic and looks sh*t.
5. The biggest problem was the design of the front case case vent (hole) and the solid front panel. If you try to exhaust, the pattern design of the vent and the solid panel causes turbulence if the fan goes above 800 rpm. Effectively the air being pushed out bounces back into the fan off the panel. This significantly increase noise from the fan. Having the fan as intake results ends up with similar issues due to the pattern of the vent.
6. Plus the sheet steel used is the cheapest you'll ever see.
In all, there have been little follow up reviews past lunch. Hardwareshaucks (i think that's how its spelled) promised to do a follow-up video from his inital review. Don't think he did.
Its like they designed the case and didn't even test it; or they didn't give a shit. Issues that could have been fixed as follows:
1. used a vented aluminium panel instead of glass.
2. Simply increased the space for the cables by 1cm. Easily done given the construction used.
3. Just found a better location for the SSD mount.
4. Better magnet, increased width, and made the part out of metal.
5. Used thicker steel so the metal won't flex. So they could have just had a round opening instead of the pattern. Also should have paced venting holes on the aluminium panel.
Illumna97
Where to start:
2. If you ..."
Thanks very much for the in dept answer! and i really hope you can sell the case... like passing on the curse in this matter :D
I'm very glad i went for the Ghost S1. I was just looking for an upgrade to my fractal design node 202, since it ain't the best looking case there is ayy? :D, but then i reminded myself on why i wanted to have an itx build in the first place and that buying a case as big as the shift would be in conflict with my philosophy "smaller is better".
I just really hope that my girlfriend could think that way :\XD
Bangle
147
112
About those power quesions above, I saw the dude from nfc make a 1080ti s4 mini and he used a 400w psu for that.
Mind you it was a 1080Ti mini. But you are right, a 500/ 600w PSU should be fine for this build. I currently have a 700SFX-L which is a bit over kill. Might sell it for a 600w SFX unit.
Just two questions. Is the noise profile between the 92mm fans on SFX and 12omm fans SFX-L significantly different? Should just stick with my SFX-L?
Reactions: Beardedswede
