shipping to the eu is 3 weeksshipped today,may arrive in the next two days.
if it has been tested by the guys selling the can it means that it works with the side pannels closed
You do know that the nore graphics heavy game you run. And the higher resolutions. The less important the CPU is. Most of the time the GPU is the bottleneck but if you got a powerhouse of GPU then I get why you get a 600 dollar CPU it's by the way not 50% faster. I believe it was faulty numbers. They ran the CPU on half the cores.Well, will you look at that?! I hadn't watched that build video in quite some time, so thank you for pointing out that it showcases the AIO I had questions about. That would've been very useful in your first response, instead of the seemingly condescending undertones your reply had.
As far as calling anyone a liar... If you read back through what I typed, I didn't make any such accusation. I made the point that I'd rather check multiple sources (specifically outside sources) before spending my money, which is only common sense in my book.
Thanks again.
With the 2nd batch on the horizon, I'm planning my long awaited Ghost build (I sadly missed the KS)... I wanted to go with Fractal Design's Celsius S24 for CPU cooling, but I recall JayzTwoCents trying to use it initially in his Ghost build, but the tubing made it so the side panel wouldn't slide into place... Does anyone have experience using the Celsius S24, and would you say that the tubes were flexible enough to fit in this case without negative side effects? I know it was used in thermal testing on the first page of this thread, but from Jayz video, it didn't look like the tubes had any chance of being bent enough to fit.
A huge selling point of that particular AIO is the fan headers on the rad itself, not to mention it's the best performing AIO in the Ghost's thermal tests... but if the tubes turn out to not be flexible enough for this case, does anyone else have any recommendations? I'm pretty against RGB for the record, and I plan to pair whatever rad I choose with either a pair of Silent Wings 3's, or or pair of Noctua NF-F12s. Thanks in advance for any advice you can offer.
Not sure if it's just the picture, but the color of the Pangaea looks quite different than the one showed on the website. The one shown on the previous page has some brownish tint to it. If that's more color accurate, then I may have been convinced to switch from the silver.
Was hoping for a batch 2 release around payday, midle of the month makes it harder to convince the wife that a 200$ case is a good idea o_o
