You might have too much thermal paste on. It's great in thin layers, but starts to act as an insulator if too thick. I'd try reapplying with the correct amount if you think this is the case.
Hey, @Kmpkt , have you received your panels back from powder coating? Can’t wait to see the outcomeYou might have too much thermal paste on. It's great in thin layers, but starts to act as an insulator if too thick. I'd try reapplying with the correct amount if you think this is the case.
Still waiting on mine here. Dont forget to post lots of build pics!On the way to pick mine up now boys!
Hey, @Kmpkt , have you received your panels back from powder coating? Can’t wait to see the outcome![]()
Also check if your fan ramp up to its max speed (2600/2700 RPM) during stress test. If it does not, check if your fan is plugged into correct ( cpu header ) or maybe your bios fan tuning utility is holding it back. Also as Josh mentioned, Prime95 stress test is totally unrealistic for ur cpu/cooler. I always use Aida64, even this stress your cpu a lot, much more than a real world load would but its necessary for testing stability. Make sure you have the latest bios. Also its worth checking which thermal paste was used and how it was applied ( one comes with Noctua L9i is good far better than cooler master stock thermal paste).
The first photos look excessive. The second one looks about right. Hope this fixes your problem!
