where do you live? if its build in taiwan, i will get it soon too!
cant wait.
Malaysia . No issues with customs either
cant wait.
What’s your Order#?Malaysia . No issues with customs either
I need help.. I think I got the wrong Dell 330w adapter:
Is this right?
Thanks.
Look what I got today boys !
@7amad
As far as volts, amps and watts are concerned. It is correct. AFAIK original dell charger usually carries Model Number DA330PM111, yours is different. It might be a replacement charger. Where did you bought it from ? Replacement chargers are fine, as long as they are good quality. I bought two, one DA330PM111 and other being sold as "replacement charger" ( for one third the price ). Just by looking at the charger, I could tell that the replacement charger is not good quality. If you paid the full price, you should contact the seller. Or just use it, if it works fine then it doesn't matter.
Here is mine.
Then that's probably it a European version since its from the UK.Looks like my EU bought adapter, has Finnish & Swedish warning texts etc.
My brick runs a 1080 mini without sweating so I guess it's a genuine brick.
Is this right?
Thanks.
@7amad
Here is mine.
Do you think Noctua NF-F12 would fit ? Its height (25 mm) might be a problem. Maybe Josh can confirm.
Thanks and Congrats#1239
Both LA330 and DA330 power brick are made by well known good OEM for laptop charger or power brick, AIO psu, etc.
LA330 is made by Lite-On Technology, and DA330 is made by Delta Electronics, both are Dell partner.
So don't worry about their quality.
Cheers.
I can't wait to see people who have the ALL-BLACK side panels too!Look what I got today boys !
I'm hype for your results and build log!Order #1168, still awaiting tracking info.
I'm getting anxious and currently working on fine tuning my 8700k/32gb/1080 build to get it as cool as possible. Still going through the tedious undervolting process, then I will work on the GPU, then RAM timings and such, then I should be ready for the heart transplant when my case arrives.
Same with me, Order #11xx, still awaiting tracking info too.Order #1168, still awaiting tracking info.
Your case has been delivered earlier than mine, i'm in Indonesia.#1239
