Completed SFFtime presents: P-ATX V3 - 10.4L evolution of ATX console case
Mackan
315
164
Hi, it is in production, should be ready in a few weeks :)
Looking forward to get one. I assume you were otherwise happy with the prototype except the "mistake" with the front panel they made? It seems sturdy enough? And I assume you will offer it powder coated in black?
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Yeah it was very sturdy, much more than I expected. Just fixed a small tolerance issue around the pci bracket and mbo IO, everything else was fine.
Standard white and black for start :)
Reactions: DrHudacris
Nightblade
294
244
Quick question(though the answer may not be), if I were to put a Micro ATX board in this case, would I be able to fit a 2 slot GPU and a single slot accessory card(a sound card, a m.2 adapter card, or additional usb ports, etc.)? or would the bottom of the board block part of it?
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Hi, I don't think so because mATX is not that shorter compared to regular ATX, only 6cm. Maybe if a low profile card is really low.
Meekyuu
Darn, looks like the new Barrow Pump / Block / Res combo is 4mm too large at 63mm.
Meekyuu
They actually do have a 10w pump block combo that should fit, at around 55mm with koolance LPs I think? I might actually give it a try, considering the most you could probably fit in the case is a thick 280 with a flexatx psu
Reactions: riba2233
Mackan
315
164
Regarding pcie risers, do you know what 4.0 risers will fit this case? E.g. a direkt Linkup one?
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Yes, linkup will fit (this style, double reverse: https://linkup.one/linkup-ultra-pci...m-designed-for-itx-nvidia-itx-amd6000-series/) but will limit gpu height if you use 2slot gpu with an ATX board, but honestly shouldn't be a problem, there are barely any 2slot pcie4 gpu's and they are not that tall.
Also this one fits with full compatibility:
Also if anyone has old style gen3 risers from sandwich cases they will also fit, and I will offer cases without risers so you can save money if you already have riser.
Reactions: Mackan
Json188
Just asking, the size of v3 is still the same with v2, right?
Just wondering if i put atx motherboard in, will it still fit msi rtx 3070 ti gaming x trio? I do think it will not fit though.
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Hi, yes internal size is the same, outside dims are very slightly different but like 1 mm here or there.
Not really since it is a 3slot gpu :|
Meekyuu
What week of june do you believe you'll be able to put up the products for sale? Mostly just want to ensure I can grab one and forget about it until it gets here, been very busy of late. XD
Super eager for a 280mm custom loop flex atx build with an ITX board. :>
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Not sure at the moment but I will write as soon as I hear some news.
Houdini
156
82
riba2233
2,000
2,608
Croatia, EU
www.sfftime.com
Big update everyone, got my hands on packing sample, and it looks very good imho :) Enjoy some pictures and "professional" video:
