I recently built my first gaming pc by myself, and it was great fun. But now that I'm done, there is a large gap in me that needs to be filled!
So i first thought about watercooling (just for looks really), but the watercooling support of mitx cases (mine in particular) is either rather poor, or they are way too large. At that point, I started to think about making a custom case, read up on all the people who already did it (M1, Nova (now Cerberus), Compact Splash and the likes) and now i started to design my own! In this first post you will find the most recent images and specs. You can find all updates in the second post
EDIT: The case and PC are finished! Click here to go to the final update post.
So here it is:
As you might have noticed, the case has a somewhat unusual layout.
All the connectors to the motherboard, GPU and PSU are on the bottom of the case, hidden inside a small chamber wich raises the components to allow for more room for said cables.
The entire case will be standing on aluminium case feet and thus raised ~1,5cm off the ground, so cables can be routed out of the underside of the pc in any direction, or i could even put a hole in the table for ultimate clean-ness.
This case is made using 2mm steel panels powdercoated in black and three 3mm acrylic panels for an unobstructed view on all of the components in there. All the panels are held together by Parvum Modding Cubes, which are also used in every Parvum case.
The case supports:
Hardware:
Mini ITX Motherboard
Full Length GPU
SFX PSU
As many ssds as you can find space for
280mm radiator, up to 60mm thick or up to 30mm thick in push-pull
D5 Pump
So here it is:
The case supports:
Hardware:
Full Length GPU
SFX PSU
D5 Pump
