... but they are doing a strange thing where they applied a $150 discount after I checked out, but on the receipt they credited me $150 for the additional games & promotions.
LOL wut
With the weight of the case and the components, I would say the weight distribution of the hexagonal S401 handle helps a lot. if you could maybe widen it in the center and plastisol your S402 concept handle, I think that would help while still being (hopefully) cheaper.The handle might not have a great feel to it and if not, I'll probably go with option #2 which was to find some nylon straps similar to kayak handles and see if I can get those to work. The flexibility of those would be great for traveling and they would be more comfortable. I'm just a little worried about the construction and potential for failure.
I have screws that I can include with any orders that would allow for a thicker panel to be installed. I would ask you to contact me directly though if you are going to want these so that I can make a note on your order (when the S402 is available) and get them to you.
I don't have one ready but I'll get one next week for you. I'm out of town right now and don't have consistent time or access to my CAD workstation.Do you have a rendering of S402 with GPU + 120 aio installed?
No worries, thank you for your work. I'm very excited with this case--I don't have one ready but I'll get one next week for you. I'm out of town right now and don't have consistent time or access to my CAD workstation.
Sorry, for some reason I'm not getting notifications in my e-mail again when someone replies to this thread. Unfortunately, the S401 is no longer available and I have no plans to produce more. The S402 prototype has been promised to be ready for shipping to me by January 10 and should things go well with that, I will submit the order for 100 units to be produced 6-8 weeks later.Hi
Is it still possible to buy a s401?
Just based on the numbers you've thrown out, I don't see how both of those can fit in the S402. I'm still working on getting those renders though and now that I know what specific AIO you're wanting to use, I might be able to get you some specific clearances for the GPU length. I'll try to get you an answer tomorrow afternoon.No worries, thank you for your work. I'm very excited with this case--
Oh, to be specific, I'm planning to fit 1660 super strix with 243mm length and beside it a ROG Ryuo 120 aio with 120mm length. Thats a total of 363mm.
The case being 368.3mm in length, do you think
a) it would fit in the case with the mounts you setup by default or
b) do I need to drill and add a mount to the far right of the case for the AIO?
If possible, maybe you could make the mount for the aio on sliders/rails that way it would allow for minimal clearence differences. It might not gaurentee perfect fitment for @Jerdz, but it might help for some people, since not all aio's are the same, and maybe some horizontal movement would make something fit, where it might not have before. Just a thought, but it might not be possible with your current design, but thought it'd be worth a mention.Just based on the numbers you've thrown out, I don't see how both of those can fit in the S402. I'm still working on getting those renders though and now that I know what specific AIO you're wanting to use, I might be able to get you some specific clearances for the GPU length. I'll try to get you an answer tomorrow afternoon.
For people wondering, I would strongly recommend NOT getting an AIO where to tubes come directly out of the block. (Like the liquid freezer II) because it will be too hard of a turn to route tubes.
Thanks for your suggestion, I understand. I don't want to mess with the design and prolong the release as well. I think I was crazy anyway; planning to pair a 1660 super with a 9900k.Ok, below are renders based on the latest revision of the S402. Keep in mind that things are fairly static in terms of layout. I don't want to tweak too much of the layout or I will have to get a second prototype made, further delaying the S402 (by up to 2 months). As a result of the renders below, I realize the following changes will be investigated:
1. USB front panel mounts might be relocated near the PSU.
2. PSU mount will need to be moved closer to the "top" of the chassis to provide more clearance for 120mm radiator. A few mm should suffice.
3. Mounting holes for the drive bracket may need to be adjusted in order to allow the radiator to mount closer to the front face of the chassis.
The radiator model I'm using is not exactly the same size as the Asus Ryuo, with dimensions of:
156mm x 118mm x 30mm
The GPU model I'm using is ~172mm in length.
Due to mounting hole differences by manufacturer, I'm not entirely sure how differently the Ryuo would mount and consequently what additional GPU space it would allow. With the rendered radiator, the Available GPU length on the current S402 revision would at maximum be 189mm. It might be possible to rotate the radiator 90 degrees to provide more length on the GPU, but if it were me, I would opt for a short 3-slot GPU than a longer 2-slot GPU. Either way, I can't find enough free space to allow for a 243mm GPU in combination with a 120mm radiator. The overall length of the S402 (in the direction of GPU length, read: front to back) is only 325mm. The 1660 super strix in combination with the Ryuo is going to be over 363mm minimum.
Instead of the Strix version, I would recommend the shorter Phoenix 1660 Super version. At 174mm in length, it would provide a lot more tolerance for the 120 radiator.
I'm excited about the prototype, it comes tomorrow/in a few days right?
Will it fit itx motherboards with integrated IO shields?
ROG STRIX Z390-I GAMING | Motherboards | ROG Philippines
Best Intel Z390 LGA 1151 mini-ITX gaming motherboard with advanced cooling, futuristic styling with RGB lighting and the latest connectivity dual M.2, USB Type-Cwww.asus.com
I'm planning my HTPC/server rebuild - will a 2060 mini at around 210mm long work with a 2.5 drive stacker?
The plan is to somehow cram a bifurcated riser with a 2060 + sata expansion card, and between 6-10x 2.5 SSDs into the case. Alternatively I might have to settle for 6x SSD and an Asus hyper M2 SSD card.
What would be interesting is to also have a utility expansion above the motherboard (similar to the silverstone ML06) so that additional LAN ports via a m2 e-key->mini-pcie card could be mounted up. But I think this would add unnecessary cost for something no one would use, so I might end up dremelling a utility slot myself.
Awesome case! Looking forward to seeing it in production.
