Pictures of the Demciflex filter
Those filters are glorious! I don't know why but it looks way better than two standard sizes put back to back. Really glad you were able to work these out with Demciflex. Just perfect.
Got about 3 hours sleep last night. Running on fumes, but I did manage to get all outstanding orders shipped today. I even got pictures of the filter but of course I left the SD card inside the camera at home. I also managed to measure the spacers when installed to see the delta between the C7 with and without spacers. Without the spacers, there is 5mm of clearance between the C7 and the vented panel. With the spacers that gap improves to 10mm. Keeping in mind that the steel vented panel adds 1mm of clearance because of the rolled edges, the overall height for a CPU heatsink/fan improves from 52mm to 57mm. You might be able to fit a 58mm cooler in with the spacers but it would be tight and you'd definitely have to use the steel panel for that extra clearance over the acrylic.
Hope things take a turn for the better as far as sleep goes. It's been a bit unnaturally warm here so that's what interrupts my sleep sometimes. The info about the spacer clearance is good to know. If it were me, I might be perfectly happy stealing the last couple of millimeters with a washer on the screws. Doing that to cover the whole ~13 mm was a bit hard to sell, but if it's just the last little bit, that wouldn't be too bad. I'm not throwing out my Noctua yet! (I swapped to a slim Thermalright fan and brought my lightly OC'd 7600K back to full stock settings. I'm hoping the extra 60mm will make enough of a difference to maybe go back to trying to tweak upwards a bit. Sound profile is still pretty great!)
Couple of quick shots with the case layout + the GPU ports. Like I mentioned before, cable management is pretty dirty ATM and needs a cleanup later on, but mostly making sure everything was working. Placeholder CPU fan taking up as much space as humanly possible haha. No issues with the GPU ports.
That EVGA card and the Wraith cooler are <looks up a word other than "glorious" because I already used it in the post> spectacular! I didn't realize those patterns on the card lit up. That's fantastic. It's also too bad that the Wraith doesn't fit in many low profile cases because it's hands-down the coolest stock cooler out there.
