S4 MINI Classic (S4M-C)
6,126
5,032
Belgium
Yeah, I didn't pay too close attention :oops: They do have VGA (ha!) and you could run a USB monitor :\
Often times, VGA on enterprise boards are supplied with an ASMedia chip or even a Matrox G200 and only support basic output. If the board doesn't have a digital connector and specifically mentions Iris support, I'd be sure to check what is supported by the output(s).
Reactions: Soul_Est and |||
loc125
26
50
San Diego
hey guys, im new to the nfc s4 family, i have one question. is it possible to power both an m.2 and a ssd running the 6700T, asus 970 mini with hdplex 250W with voodoo 350W brick? currently modding the case to fit the connections..... -__-
3,381
5,936
45
Victoria BC Canada
Should be able to do that with plenty of headroom. 6700T and 970 mini with a drive should live around 210-220 I believe. An additional SSD or M.2 should only consume a few watts. Also the 250W HDPlex can produce up to 400W given ample access to fresh/cool air.
loc125
26
50
San Diego
ok, golden, first - thanks for the very fast reply!!!, secondly, today is the only day since i bought the s4 from josh (thanks man) like a month ago... just got everything to fit. had a time of my life trying to get the best length for the 24pin atx connection. took me 2 weeks to get it right -__- which includes destroyed thumb and index fingers..;p..
Thanks all for your help will post a picture of the completed build ;D
loc125
26
50
San Diego
hey, ok another question, so I have both the intel i7-6700 and i7-6700T, im kind of confused on which is better for a gaming system. I know its about how hot it gets but its kinda stressing me out as to the final build. -__-. im tying to build this for deployment, any info is much appreciated.
flacman
128
61
@Josh | NFC question on the PicoPSU - I just ordered a 160XT+192w adapter kit this morning; what are the default connectors (type and count) that come with the unit? I've been trying to find videos and reviews but it looks like I'll have to use a molex to PCI-e adapter?
Josh | NFC
Not From Concentrate
Jun 12, 2015
1,868
4,468
Biloxi, MS
www.nfc-systems.com
GREAT question! That's another video idea. You will need a 4-pin to 6-pin adapter.
With the PICO 160XT you get the following in the box:
1. Pico 160XT with direct attached power wires that end in 4 PCIe pin male
2. Removable CPU 4-pin harness
3. Removable harness with one SATA power connector, and one, 4-pin female molex.
4. PCIe 4 pin to DC 4 pin mount adapter (shown below)
5. Two ity-bity screws for mounting DC 4 pin mount.
Reactions: Soul_Est
loc125
26
50
San Diego
quick question, on the S4 mini build, is it recommended to install the motherboard IO backplate or complete the install without due to heat?
kgh00007
Hey Josh, would the Zotac GTX 1060 AMP fit in the S4 mini? Tom's hardware are reporting it as 8.27" long? It's rated at 120W, but we'll have to wait for reviews to see.
I'm interested in that or the RX480.
And how about one of those and an i7-6700 on the HDplex power supply, would that combination work OK?
Cheers!
flacman
128
61
Cheers!
Wouldn't you consider the Zotac 1060 mini instead?
Your selection is fine for the HDplex, Josh runs a 960 on his PicoPSU and others here have been using 970 mini.
kgh00007
I would,but I don't like the idea of the solid heatsink. I much prefer the heat pipes and the size of the AMP and at 8.27" maybe it just will fit!
