Quick question. I currently have my S4 positioned horizontally underneath a glass monitor stand. Needless to say it doesnt get the best airflow, but i don't suppose a peak of 70C on my SSD and HDD, 95 on my CPU, and 90 on my GPU is healthy huh?
Is there a pressing need for me to rearrage my setup
As was mentioned, most the parts are good to operate at 90C, and I have some industrial units that operate that 24/7. However, your memory is not good to operate at high temps...(70 should be OK/in spec) for the ram and SSD, but heat does kill memory as I have definitely found.
Keep an eye on the system during overwatch...I've seen that game and HoTS kill PCs (luckily no S4s yet) from heat...and I haven't put my finger on as to why yet...but just do some googling...its actually a thing. it's weird to me cause Crysis 3 and MWO pull more power than those two do on average.
Hey guys, thanks for the reply. By header I meant this thing:
There are two more on the other side I think as well. Two of them are the same and I think the other is different. I looked on the pico wires and I think they say 22 AWG?
Anyways, does anyone know where I can buy the plastic header for the accessory harness and 4 pin CPU power as well as the metal pins that go inside of them?
Thanks!
QinX mentioned before that they might be JST connectors...I actually don't know:
