S4 #95
CXH4
136
87
SUPER clean setup!
Thank you for sharing my friend!
I have 3 more pictures, and thank you for the compliment! :)
CXH4
136
87
Do you still lower the power target of CPU and GPU? Why have you changed your PSU setup? Thanks!
Yes I still lower the power targets for both the GPU and CPU, however I raised the clock speed to 3.4 Ghz on the CPU without the boost to 4.0 Ghz. I changed the PSU set up because I find the 160XT more reliable for my uses. I haven't benchmarked the system with Prime 95 and Furmark to test the power consumption at a full system load, it may stay under 160 watts. I'm not sure yet, but if and when I test it, I will post the results. :)
Reactions: lordzahl
