Razer Blackwidow Chroma V2 Cool. Thanks.
K kulbida Average Stuffer Jan 8, 2018 63 50 May 6, 2018 #21 Aoq1 said: Razer Blackwidow Chroma V2 Click to expand... Cool. Thanks.
B bananaboy93 SFF Lingo Aficionado Mar 28, 2018 112 18 USA May 9, 2018 #22 Aoq1 said: Click to expand... How did you get the colored caps? did it come like that?
A Aoq1 Trash Compacter Mar 16, 2018 37 27 May 12, 2018 #23 bananaboy93 said: How did you get the colored caps? did it come like that? Click to expand... Ordered from Amazon
A Aoq1 Trash Compacter Mar 16, 2018 37 27 Jan 16, 2019 #24 Upgrading to RTX 2070, kindly advice on which card could fit in with no modding (I prefer to have Zotac RTX 2070 though i don't know if it will fit) Advise needed here !
A Aoq1 Trash Compacter Mar 16, 2018 37 27 Jan 17, 2019 #25 Aoq1 said: Upgrading to RTX 2070, kindly advice on which card could fit in with no modding (I prefer to have Zotac RTX 2070 though i don't know if it will fit) Advise needed here ! Click to expand... Bought already the GIGABYTE GeForce RTX™ 2070 MINI ITX 8G
A Aoq1 Trash Compacter Mar 16, 2018 37 27 Jan 20, 2019 #26 Aoq1 said: Bought already the GIGABYTE GeForce RTX™ 2070 MINI ITX 8G Click to expand... Fits perfectly with no mods thermals at 80 degrees Celsius playing PUG 1440 res at ultra settings with average of 100 FPS
kittysox Cable-Tie Ninja Aug 8, 2017 156 195 Oklahoma Jan 20, 2019 #27 thing looks fantastic! But that xbox is really slick to! great looking setup Reactions: Aoq1
A Aoq1 Trash Compacter Mar 16, 2018 37 27 Mar 3, 2019 #28 Solved the loud noise on the RTX 2070 gigabyte by changing the fan to Noctua A15x14 Had to do some fabrications on the fan to fit on perfectly Thermals are higher by 1-2 degrees Celsius but its worth the difference in noise, I also keep the fan now all the time at 100% Last edited: Mar 3, 2019
A Aoq1 Trash Compacter Mar 16, 2018 37 27 Mar 17, 2019 #30 After switching the stock fan to the Noctua A15x14, I solved the acoustic problem but while gaming the gpu reaches very high temps 85 degrees Celsius. I am considering reapplying thermal paste, it seems like my last resort
