The dimensions of the GPU in the picture? Or the dimensions in comparison to my Zotac 1060?
He's talking about the dimensions of your card, measured as indicated in the picture
Ah, well I'll get right to that then.He's talking about the dimensions of your card, measured as indicated in the picture![]()
Which riser is it? Sometimes reseating it helps.
If you don't mind, could you measure these dimensions on the card?
So that's length from the outside face of the rear bracket to the furthest part of the card.
And height from the bottom of the PCIe connector to both the top of the power connector and the furthest top part of the card.
Those are the overall dimensions of the card, if you find any errors in this please let me know.
One more question, does it turn the fan off at idle?
So what riser?
You're lucky you can test with a GTX 1060. There's barely any stock in Australia to start with.
I've received most of my kit and have lightly tested the 160XT + 6700T with web browsing, application installs.
Normal power draw (as per CPUID HWMonitor) is around 16 watts (min) to 40 watts (max).
Temps hovering between 26-28 degrees C using ID-Cooling VC45, Noctua NF-A9x14 PWM and Arctic Silver grease.
Looking closely, I may have to tighten one of the screws (off by 1-2mm compared to remaining 3) on the heatsink mount, but looks like it survived YouTube.
Well that's making me consider the 6700T despite me being a bit short on cash. Have you benchmarked the CPU with Prime95 (Or any other benchmark) yet @flacman ?
As for the 1060 I wish I could've gotten an ASUS mini itx 1060 if those existed currently. The 1060's were in stock last week, but perhaps that was for the US only? Or only for a short time?
Once I get back home (2 weeks), I plan to remount the HSF and do some testing using XTU.
Spent a lot of time on the weekend trying to figure out why the system/motherboard initialization hangs for about 10 seconds prior to booting to Windows. The 950 Pro is mighty fast in booting the system when the logo comes up (AS SSD reports 2.2 GB/s read, 1.4 GB/s write) - once I manage to reinstall the OS as GPT and disable CSM, perhaps I'll get a 2.5 GB/s read score.
Seeing the leaked performance benchmarks for the AMD Radeon RX 460 depresses me slightly. Was kind of hoping (pipe dream) for a GTX 960 consuming less than 75 watts. Maybe a future GTX 1050 (Ti) may be a better fit (~GTX 970 performance at 85-100W peak) for the system.
As for your system - if the Dell 330W brick is crashing, have you considered sourcing a HP/Voodoo Firebird 350W adapter?
@CXH4 how loud does your Zotac 1060 get? Read on another thread here that it super loud compared to the EVGA ones.
Zotac 1060 comes to about $370 AUD shipped for me vs. the EVGA 1060s ($410 AUD) which are out of stock with no ETA.
