Yes I still lower the power targets for both the GPU and CPU, however I raised the clock speed to 3.4 Ghz on the CPU without the boost to 4.0 Ghz. I changed the PSU set up because I find the 160XT more reliable for my uses. I haven't benchmarked the system with Prime 95 and Furmark to test the power consumption at a full system load, it may stay under 160 watts. I'm not sure yet, but if and when I test it, I will post the results.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
