RTX A2000 Full Copper Low Profile Single Slot Edition - aka A2000 SpongeBob Copperpants Mod
robbee
n3rdware
760
1,099
I'm afraid the mounting pattern of the RTX A2000 is completely different than traditional cards. Furthermore, it is low profile so the block is too large and clashes with a lot of components that are taller than the die and memory.
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Hi All,
Sorry to hijack the thread, but I was wondering if someone could help me out. I'd like to install this card in an HDPLEX H5 using the passive GPU add-on kit:
However, HDPLEX hasn't been able to verify if this card is compatible, since it requires printing a the 1-1 scale cutout and seeing if the heatsink will be able to match one of the mounting patterns.
1:1 cutout: https://hdplex.com/pub/media/image/...rview/HDPLEX.GPU.Copper.Base.Compatibilty.pdf
If anyone could verify or point me in the right direction, I'd be most grateful.
I've attached a simplified model of the A2000 PCBA to my first post of this thread. Maybe this would help, but looking at the drawing from HDPLEX you'll probably need to modify/get a custom cold plate to make it fit.
msystems
661
1,169
I don't know what the A2000 pattern is, but the hdplex gpu block patterns haven't been updated since RTX 2*** / Vega 64 and they aren't compatible with 30 series (which is a shame because they are very good copper blocks).
You can also try using an image of the board with an overlay of the pattern in photoshop or similar to check hole patterns
